Question about Dell Dimension 3000 PC Desktop
Dell dimension 3000 doesn't recognize CD drive
I am trying to fix a dell dimension 300 that does not recognize the CD drive. I replaced the one the unit came with, with another one but the CD drive is still not recognized. Any suggestions as to what I should do? Thanks.
  • multi_media Jun 29, 2009
    Cables are connected. The CD runs but the computer does not recognize it, so of course it does not read and CD.
    President:
  • Dell Master
  • 1,314 Answers
Try making sure the cable that connects the motherboard to the CD drive is seated correctly and, if it is, try replacing the cable that connects the motherboard to the CD drive.
Posted on Jun 28, 2009
  • Kevin Shafer
    Kevin Shafer Jun 29, 2009
    Did you switch out the cable? You gave me a bad rating but didn't do everything I suggested???
Dell dimension 3000 doesnt recognize cdrw drive
Drive might have gone bad possibly? Or power the PC down completely push the power button for about 1-2 seconds to discharge the PC then plug it back in and restart the computer. If this does not work and you still cannot see the device. Check the cables and make sure they have not come out or are loose. If this is not the problem then you may try downloading the driver file for it at Dell.com replace drive if necessary. John
Apr 19, 2012 | Dell Dimension 3000 PC Desktop
Dell Diminsion 3000 can not recognize blank CDs, Is there a driver i can install to fix this problem?
Hi, there is maybe a firmware upgrade for the drive here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_CEL_3000
It should be under the CD/DVD.
Please unzip the file after download.
Or the drive could have a defect.
Try to change it out with another IDE drive.
Aug 29, 2011 | Dell Dimension 3000 PC Desktop
I have a dell dimension 3000. I wiped the computer, installed OS disc, but it says FAIL every time I try to do anything with the utilities & drivers disc. I also have no internet because it won't...
Right click on My Computer>Manage>Device Manager>does your CD-ROM have a yellow ? or ! on it?
If so, then you somehow need to install a driver for your computer to recognize your drive. If you can get an external CD-ROM that connects to a USB port, maybe you can install the drivers that way. Once that CD-ROM is working, then you can get the drivers installed for your modem. Hope that helps!
Aug 04, 2011 | Dell Dimension 3000 PC Desktop
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 CD/DVD drives not working
You can download the drivers from dell website, download.com, and many other sites. Download, then double click on them to install them. Once installed, reset pc.
Sep 13, 2009 | Dell Dimension 3000 PC Desktop
Dell dimensions not reading cd
You could first go into the device manager and uninstall the CD. When restarted, the computer will identify it and reinstall it. If it is still unable to read the CD, try several other CDs. If that fails, you probably have a CD drive that has failed and will need to be replaced. They are not very expensive these days.
Jan 22, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Reset to factory settings
Get your Recovery CD, and just completely reformat the hard drive, These discs should guide you threw this. If you do not have the Recovery CD's Then you may have to order them from Dell.
Nov 25, 2008 | Dell Dimension 3000 PC Desktop
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Dell Dimension 3000 PC Desktop Logo
400 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
