Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Green line going down almost to the middle of the screen
There is a green line going down almost to the middle of my t.v. screen. My t.v. was bought in 2003. how can I fix this myself with out it costing and arm or leg. or should i just get a new t.v.
I have the green line too. What do I need to do?
Posted on Nov 26, 2007
  • 1,694 Answers
Replace both convergence IC's STK392-110 X 2............T.
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
Mar 10, 2008 - Posted on Mar 17, 2012.
Jan 16, 2016 | LG Televison & Video
47LD450 LCD tv has green line down middle of screen
Sorry, you can try reconnecting connectors on T-con board (small rectangle board at top center under metal shield)if you are lucky, but it is likely a panel failure. It won't hurt to watch it as it is, if it doesn't bother you
Feb 16, 2014 | LG 47LG50 47 in. LCD HDTV
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
I have an orange line down the middle of my screen
i have a thin green line down my computer screen how do i get it off ?
Jun 29, 2009 | Hitachi P42H401 42 in. Plasma HDTV
Green line down the middle of the screen
Often times this issue is caused by either a loose or damaged VGA cable. You can verify the issue often times by firmly wiggling the cable and watching to see if the line disappears. If that does not resolve the issue you will need to replace the monitor
Apr 23, 2009 | Computers & Internet
Line down the middle of my sharp aquos 42 inch
first make sure it does not come from the signal. If its really from the tv and look like a darker line it can come from the lcd control unit but most of the time its a dfective lcd panel
Mar 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Oct 19, 2008 | RCA 20F512T 20" TV
42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Aug 29, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Sounds to me like its your green tube. Kind of expensive replacement, but easy.
Jul 24, 2008 | Sony KP-51HW40 51" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
335 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
