Question about Hamilton Beach Coffee Makers & Espresso Machines
I own a brew station master and we have not had it a year yet and when we put the water in to brew 12 cups it only brews 4-6 cups we have cleaned the coffee pot with a cleaner but it has not helped
  • 14 Answers
If the model you have is a 74214, I had the same problem. I had to repeatedly turn the pot off and on to get a whole pot of coffee. I returned the first one within 90 days back to Walmart with no receipt. They exchanged it with no problem The second one did the same thing so it went back also. I was going to exchange it for the same model but got lucky and found the next upgrade model (47665) on sale at that time. Not only did Walmart credit me the cost of the faulty one, but refunded me the $5.00 difference!!!! I've had the better model (47665) for about 9 nonths now and had a problem with a waher/gasket falling out causing the coffee to run all over the place. I called Hamilton Beach customer service at 1-800-851-8900 and explained the problem. They informed me that the tiny plasitc piece that holds the gasket in place had broken and I would need a whole new tank. They then informed me that for the $5.00 cost of shipping, they would send me the new tank FREE OF CHARGE!!!!!! AMAZING. I love Hamilton Beach and know that they stand behind their products. Call them at 1-800-851-8900 and explain the problem. I'm sure they will remedy the issue at little or no cost to you and if it can be repaired, I know they will send the part with instructions at no cost. Good Luck to you. Katherine
Posted on Jul 13, 2009
My brew station leaks water all over the counter top before it is brewed.
Mine Too! So frustrating. I have to take out the coffee filter, then remove the piece that it sets in. Make sure and clean the spring and the hole in the bottom. This seems to cure the problem until the next time. It seems to get plugged up quickly. I have learned to rinse it out every time I make coffee.
Feb 12, 2015 | Hamilton Beach Brew Station 12 Cup 48465
Why won't my brew station brew the whole 12 cups at on time? We have to constantly turn off then on again.
You probably need to de-scale the brewer. Use cleaning strength vinegar and run it through the brewer until vinegar comes out, then let it sit fir 4 hours or so, then flush plenty of water through to get rid of the vinegar.
Sep 24, 2014 | Hamilton Beach 47900 BrewStation 12 Cup...
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Brew station is extremely slow, suspect it needs cleaning.
You can run a cup of vinegar through the machine. Run it just as you would making coffee, except without the coffee. Run water through the cycle at least twice to remove sediment and the vinegar. Works like a charm.
Jun 16, 2010 | Hamilton Beach BrewStation Deluxe 47474...
I am interested in purchasing this 6 cup brew station, but all pics I see use travel mugs. Can it be used with regular 10 -12 oz ceramic mugs for home use? How about 6 oz cups that match Corelle...
How does the coffee get into the cup? If it brews directly into the cup then the amount can be controlled by how much water you put into the maker. If it is a 6 cup then it must hold the coffee in a reservoir. Do you have to push and hold a button to dispense the coffee or do you push and wait for it to fill your cup? If it is the latter then it will need to know how large or small the cup size is. Is there a setting for that? If it is a push and hold method then you control the coffee flow so size is up to you. As far as it being a travel mug or ceramic mug as long as the mug will fit in the maker and sit securely under the nozzle then it shouldn't matter what kind of mug it is.
Feb 20, 2010 | Hamilton Beach 48274 BrewStation 6-Cup...
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Aug 28, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Slow brew time / water disappears?
I have this problem with a 4 cup model. 4 cups in, 2 cups out. I cleaned it twice with vinegar (with a filter in place). The first time didn't seem to help, but the second time I got about 2.5 cups out, along with a bunch of old grounds that I think had been sucked into the pump. Ran water through it twice, and now it gets to about 3 cups.
I think the problem is just that the pump is clogged with grounds. If vinegar makes yours worse my guess is that a big piece got dislodged and is now blocking the tube. More vinegar might help.
May 20, 2008 | Mr. Coffee ISX23
Coffee Makers & Espresso Machines Logo
434 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
