Question about Sony Playstation 3 (PS3) Console
I have a Sanyo HD TV and my Playstation 2 has the red white and yellow jacks but when I plug them in I get no color. If I move them to the bottom red jack and the top green and blue jacks it works but only in black and white with poor picture.
    Scholar:
  • 106 Answers
The red and the white cables are the left and right sound
the yellow one is the only one sending a picture signal
plug it into the video in...which should be yellow on that tv, the green and blue jacks are for another type of video connection
Posted on Jun 29, 2009
2 Suggested Answers
SOURCE: Having the same problem but your solution does not work.
did you verify if your tv is set to work with PAL or NTSC?
if your PS System is European, you must set your tv on PAL
if it's American, you must set your tv on NTSC
and it will not work if you try to plug the cables in component video as you did.
Posted on Jul 26, 2009
On the insignia NS-39d400na14 im trying to hook up my playstation 2, i can see it on the screen but i don't have color and don't have any other cables i can use to add color, can i change settings
YOU HAVE NO COLOR DUE TO PLUGING YELLOW , WHITE AND RED INTO COMPONENT INPUTS, USE YELLOW PLUG FROM PS2 INTO GREEN ON TV IF YOU DONT HAVE A YELLOW JACK ON TV, RED AND WHITE ARE FOR AUDIO IN ONLY. Colorvision Services
Oct 30, 2014 | Televison & Video
Have sanyo 25in color tv with no manual and want to hook up a wiisystem it is currently hooked up to dishtv model ds25320 and family group vc8b
Connect the yellow rca plug from the wii to yellow jack on the tv marked AV1 and the red and white rca jacks from the wii to red and white rca jacks of the AV1 hookup. Simple.
Aug 30, 2011 | Sanyo Televison & Video
HOW DO I CONNECT TO TV
There are many methods to do this.
If your cable are ONLY RED,WHITE,YELLOW
1 Plug the red white and yellow cables to there corrosponding jacks on your DVD player
2 Plug the red white and yellow cables to jacks labled video IN, Audio IN. They will be colored on the back of your Tv
3 Plug in the power cable.
4 Turn it on and flip through the inputs on your tv until you see the picture
IF your cables are RED, GREEN, BLUE, RED, AND WHITE
1 Your are using what is called conponent video. This is a high definition video.
2 Three of your plugs are for video. They are Red(Cr) Green(Y) and Blue(Cb)
3 Plug the GREEN into the Y jack
4 Plug the RED into the Cr jack
5 Plug the BLUE into the Cb jack
6 Plug your power cable int o the wall if you havent alredy done so
7 Plug the other red cable into the audio right jack
8 Plug the white cable into the audio left jack
9 Turn it on and surf through the input until you find it
If you have a BLACK, RED and WHITE
Do the same as RED WHITE and YELLOW but
1 Put the black cable into the s-video slot
2 Surf through the inputs until you find the picture
If you have ONE BLACK CABLE
1 This is called HDMI(High-definition multimedia interface)
2 Plug one end into the tv and the other inte you dvd
Thank you for your time, Good luck and I hope this works
Jun 08, 2011 | Televison & Video
No sound on tv and black & white
The red, blue, and green are the component cable hookups. What you have w/ red, white, and yellow is called composite or on most TV's (AV) See if the TV has a side port for like a camcorder, etc. It will not work by hooking into the red/blue/green as they are different signals.
It is possible that your yellow jack may be separate from the red/white audio left/right jacks.
May 04, 2010 | Sony PlayStation 2 (PS2) Console
How do i connect the playstation 3 to tv, it was connected to hd tv then we have tryed to connect to normal tv and nothing. please help
You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
Jan 08, 2010 | Sony PlayStation 3 40GB System
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
How do I connect my Playstation 2 to a Phillips
First, you need to plug in the A/V cable (the cable with the red, yellow, and white tips) to the back of the Phillips TV. There should be color coordinated plugs to go with the cable. After that, plug the other end of the A/V cable to your PS2, and you are good to go with your audio and video.
Dec 06, 2009 | Sony PlayStation 2 (PS2) Console
Jul 25, 2009 | Sony Playstation 3 (PS3) Console
How do i hook up the rca jacks of my playstation 7501 to the tv?
You generally just plug the yellow rca into the yellow female rca socket, and the red and white into their respective colors... change to tv to AV1 or whichever it was plugged into.
Jun 07, 2009 | Sony Epidemic for PlayStation 1
Game
It depends if you are using RCA jacks or coax . now RCA is the best way to go . its the wires that plug in to the back of the TV colored red ,yellow and white (yellow is video) (red and white is right and left audio). Now to get to the Question at hand. Either channel down on the rc600d. to the channels below 02 should find
(av )channel if not then look on the rc600d for the tv/video button and try this. make sure the ps2 is on. a blue light on the front of it will mean it is operating .
Jul 07, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
348 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
