Question about Haier HRF10 Top Freezer Refrigerator
Haier HRF10 Moaning sound coming from Condenser fan.
I have a Haier HRF10 refrigerator.
It was working for good six years and now, this fridge started to make moaning sound. It makes sound for about three minutes and then good for five minutes and so on. It was like this crazy on and off sound for few days until I have decided to take out the parts from the back.
In the back, I took screws off of black fence thing and then I took the little cover in the middle of the thin metal. I put back the power on and it seems to me that the noise is coming from it. I can control the noise by pressing this condenser fan (I think that's what it is) or unscrew the positioning of this thing.
I can't stand the noise for now, so i unplug the condenser power off for now.
Is my problem a condenser problem that I need to replace them (and how do i do that?) or I am looking at something else.
  • greatestates Jun 29, 2009
    How do i replace the condenser fan (do you know how much this is?) or how do i oil the fan.
    Please help me with this.
    Thank you.
  • 2,418 Answers
It is the fan, Its time for a new one or try to oil her.
Posted on Jun 29, 2009
  • John Fourteen Six Jun 29, 2009
    Not too sure of the construction of your mach. The Condenser fan motor should be mounted on a slider type of mount screws on one side, tabs on the other. But again I am not sure, can't find anything on the net to help me help you. Sounds like you have gotten to it.The moaning is worn bushings causing a vibration. if you can get an oiler pin, (looks like an ink pin or a large Hypo) will have a long metal tip looks like something the Doc gives a shot with. Try to oil it or blow it out with a can of air like you blow a computer key board with. If you have to get a can of WD 30 with a red straw and just shoot it at the shaft this may do the trick.
My refrigerator has intermittent cooling/freezing and moaning. The moaning is from the freezer and has been consistent since I bought the fridge used about two months ago but it just recently started with...
The unit is according to your description is only a couple of monthes old and parts should be covered under factory warranty. Call the toll free number that comes with your refrigerator to have them get a factory trained repairman to come out and see what is the matter. There is a minimal charge for the repairman typically under $100.
Hope this helps,
PS waiting for proper repair causes most problems to get worst, so time is of the essence.
Sep 25, 2014 | Refrigerators
I Have a Haier Refrigerator, not sure if it is this model it looks the same but is stainless steel. Recently the fridge has stopped cooling. Have had it for a few years and has of late it slowly began to...
It sounds as if the fan has ceased working. If it is freezing the bottom, then the refrigerant has not escaped. If it was the compressor, the motor would have become louder and begun to rattle. If you can turn it off for a day, then turn it back on. If the fan motor starts to work, it may just have been frozen up, replace your seals . If the fan motor does not start then well it will not. Try replacing the fan motor.
Oct 03, 2017 | Haier RRTG18PABB (207 cu ft) Refrigerator
Our Amanda refrigerator/freezer has been making noises on and off (buzzing) over the past two months, in particular the bottom freezer. Today everything started to melt and the buzzing is frequent every...
It sounds like your evaporator fan motor, they last about 4-5 years. Try to see if the buzzing noise comes from the motor, usually in the freezer compartment behind a vented cover plate
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). It could be that your drain hose is clogged or frozen. Maybe the temperature adjuster go bumped.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | Amana ABB1927DE Bottom Freezer...
Haier HRF10 what would happen to the fridge without condenser
it could but the possibility is low but you willl ruin the ref doing that
Jun 29, 2009 | Haier HRF10 Top Freezer Refrigerator
Thermostat switch comes on but fridge does not cool
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
May 28, 2009 | Sanyo SR-3660S Compact Refrigerator
Our fridge/freezer is making a moaning sound. we
if the timer is making clock sound is the timer may be you have a fan making noise
Mar 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is cold cold....fridge is at approx 50 degrees
Hello lmk400,
Welcome to fixya,
You siad, your freezer is cold cold....fridge is at approx 50 degrees What could it be ????????
1. The first thing it could be is that you have a freezer that is packet to the ceiling.
And so full that it's articles are covering the air vents found in the rear of the freezer.
They are need to be clear for the cold air to circulate form and to the fridge compartment.
Yes that is correct!
The freezer and the fridge both share the same air and to restrict the air causes the other
to get warm.
And will eventually burn out your fan motor or possibly your compressor!
OR
2. Your fan motor is already burned out.
Try checking this and clearing the vents.
It will take some hours to get cold and all night to reach peak temperature, if this is your reason!
If not you should then try turning off the fridge AND, then unplugging it for five minutes.
This should reset the system if there is an electronic glitch!
If all this fails you may be low on freon and need service to add some.
If the fridge was left open a crack all night or all day by accident it will cause this!
or if you go shopping and while unloading or loading the fridge with the door wide open running back and forth to the kitchen table for some extended time to!
Gather all the cold stuff near the fridge and put them in quickly!
I gave you a lot to work with and I hope the first two suggestions are the fix and solve your problem.
Let me know!!!!
Huuum
Please rememebr to leave me a rating at our fixya site!
Oct 21, 2008 | Haier HRF10 Top Freezer Refrigerator
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Freezer cold, but Fridge only a little cool
Sounds like you have a defrost problem either the Timer /Heater or Bi-metal stat is bad. you can unthaw and the unit will work fine for about a week until it frosts up again Where was this screw they said was loose?? have them check the defrost system.
Aug 28, 2008 | Haier HRF10 Top Freezer Refrigerator
Haeir HRF10 refrigerator
Remove coil on back of refrigerator very gently and support the coil against a kitchen chair or counter. On the back of the refrigerator there is an access panel. Remove 4 screws holding the cover. Remove the bottom of the freezer compartment by removing screws and pulling bottom straight out. Remove Styrofoam panel from freezer by cutting tape along side edge. Once the Styrofoam panel is removed you will see fan blades. O n the front of the fan blade there is a spring. Pull the spring off by pulling straight forward with pliers or fingers. Remove the 3 screws holding the fan motor to the refrigerator in the rear access panel. The Motor should now be free. Unplug the plug from the connector by lock latch and pulling straight up. Now you must free the fan blade from the fan motor. Grasp the fan motor and pull straight out. This fan blade is really hard to get off. Try separating the two halves of the blade, where you removed the spring, with a screw driver. The motor is available from Repairclinic.com. Good luck.
Mar 01, 2008 | Haier HRF10 Top Freezer Refrigerator
Haier HRF10 Top Freezer Refrigerator Logo
415 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
