Question about Technics SL-BD20D Turntable
Problem with Technics SL-BD20D turntable: Sound quality deteriorates towards middle of records; fuzzy and indistinct sound. I wonder if the tone arm weight is correct (it jumps at the slightest motion on the floor). But the company says weight and tracking are pre-set and I presume can't be adjusted. Thanks for any suggestions!
  • 69 Answers
Have you got anti skate adjustment
Posted on Aug 07, 2009
Why douen't my technics turntable spin?
Take off the rubber mat and see if the belt is off the aluminum platter the record sits on you should be able to see the rubber belt when the mat is removed. If it is not there or broke it will need replaced.
Apr 23, 2013 | Technics SL-BD20D Turntable
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
I have a problem with the turntable I just purchased...
Hi, remove the platter and check that the belt has not come off. Cheers john. Styluscity
Nov 12, 2011 | Technics SL-BD20D Turntable
Hi! I've replaced my old stylus on a technics sl 20 (EPS 270 ED) by a tonar 757-DE elliptical, as it was recommended. The result is disappointing. The lows seem right, but the middle and higher range is...
You definitely want to make sure that your new cartridge is properly aligned for your turntable. This web site can help:
http://www.audiophilia.com/features/cartridge_setup.htm
If you don't feel that you are able to get it properly aligned by yourself, a local dealer should be able to help you with this for a small fee.
Mar 08, 2011 | Technics SL-BD20D Turntable
Technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Sep 22, 2009 | Technics SL-1200 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Technics SL-L3 turntable no sound until warm up
either the cartridge is bad in the phonograph tone arm.  Or the pre-amp in the stereo is bad...remember that the turntable is the only accessory that uses the pre-amp input on the stereo.  I'm betting the pre-amp is bad.
Mar 10, 2009 | Technics SL-1210 Turntable
Tone arm pushing towards the cent or the record
Your tonearm is either damaged, or your anti-skate is not set properly. It should be set to ZERO. Take a look at this video for some assistance...- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Oct 08, 2008 | Technics SL-1200MK5 Turntable
Needle drag
Hi, i know this sounds stupid but have u tried using a different record as the record your using may have a defect which wont allow it to play any further. I would also make sure that you weight the tonearm as much as possible but not to much that you wear ur needles out. Let me know how you get on. Gud luck!
Nov 18, 2007 | Technics SL-1200MK2 Turntable
Technics SL-BD20D Turntable Logo
259 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
