Question about Moen 2919 Chateau Two Handle Tub and Shower Faucet With Standard Valve In C
The water valve is off tight and water is still leaking
Show me the different types of valves used in bath tubs
  • Bill Johnson May 11, 2010
    what do you mean by valves?
  • 117 Answers
Moen and delta are the best! check them out
Posted on Jul 31, 2009
Tub spout diverter
Check the basement. There may be a valve (two valves) that someone partially closed in the past to limit how much water was used for a bath.
Dec 21, 2013 | Plumbing
I a leak under my tub, think it's from the shower, it doesn't leak with a full tub of water or ewhen you empty the tub, but when you're in the shower a flow of water comes out under the shower piping side...
Check out the faucet plate mounted on tub side for a good seal. Water can leak down this plate causing it to look like the valve is leaking.
When you are in the shower it splash's water against the valve and water will run down behind it. Check the tub spout and if you have tile check the chaulked joint where tub and wall meet.
Jun 02, 2010 | Plumbing
Bath tub leaks
Well if its not from drain then it could be from one of the supply valve (hot/cold) it is also possible that its leaking from the overflow drain. this gets overlooked sometimes because of its location. One thinks that water has to be filled that high but one might be surprised how much water gets there when taking a shower or splashing in the tub. There should be an access panel to check the valves and overflow gasket. If not remove the handles and echuns to see if you can see anything.
Mar 31, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Hi, Have a situation. My bath tub(2nd floor) is leakinge and water is dripping down to my living area (through the lower level cieling). 1) I ran the water and collected it in a bucket to see if it water...
You will have to bust out the ceiling where the dripping is occuring to get to the pipes. Before doing so, check and see if your house was built with an access door for the valves. (Look on the other side of the wall where the valves are.) I have the very same problem and am going through ceiling replacement after repairing the pipes. It is a mess. Good luck.
Nov 30, 2009 | Lefroy Brooks Bath Waste Trap for Exposed...
Bath tub water faucet leaks. It is a single handle type.
You will have to replace spring ang washers behinde valve cartridge.
Oct 24, 2009 | Delta & Single Handle Shower Faucet
My Kenmore All in one does not shut off the water after filling starts. It has even run water into the tub and over filled when not in use. Could it be the mixing valve?
I would suspect a faulty water level switch. This is a diaphragm type device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level increases, so does the pressure on the air in the plastic tube and when it reaches a certain level it activates the switch to shut off the water. Make sure there is no damage to or obstruction of the plastic tube. The switch can be tested using a multimeter or ohmmeter and checking continuity. A lack of continuity would indicate a bad switch. Sorry for your trouble and I hope this helped. Best wishes.
Sep 29, 2009 | Washing Machines
No water pressure in bath tub after turning off hot water heater
It could be back flowing into the hot water heater tank which is not full because of the leak. Even though the valve is closed on the cold water entry side, there is probably no valve on the exit side. That is how it is returning to the tank.
Sep 14, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water leak from under the washer...all water input and discharge connections are tight and show no sign of water leaks.
This could be from using to much soap or not using he detergent or unit needs sanitary cycle ran from soap build up . But i just had one that the valve itself was slowly leaking from valve casing (feel the valves ,under panel).I have also had small holes in door gasket and bellow (hose from tub to drain pump ) had a tear.
Jun 25, 2009 | Washing Machines
Water leak outside valve
You have a leak where the back plate goes up to the wall OR there is a gasket missing from the trim installation. If this is a tile shower i would suspect the first and use clear tub/tile chaulking to seal around the edge of the plate paying close attention to the grout lines.
Phil
Dec 09, 2008 | Rohl A2400 Country Bath TRIM ONLY PRESSURE...
Moen 2919 Chateau Two Handle Tub and Shower Faucet With Standard Valve In C Logo
248 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
