Question about Refrigerators
I have a GE side by side fridge. Model # GSH22VGRBWW It does not make ice. We was purchasing bagged ice and putting it in the ice dispenser tray and we could get ice now it will not release the ice. You can push the button for ice and nothing happens. You can however, hear a noise that sounds like the motor; just no ice is coming out. How do I fix this? Thanks
    Problem Solver:
  • 19 Answers
Remove the ice bin,with the freezer door open ,press the pin switch at the top of the door opening, then press the ice dispenser ...if the forks on the auger motor rotate its ok... if they dont the motor is frozen
Posted on Jun 29, 2009
Kenmore side-by-side not dispensing ice or water, the ice maker has been replaced, no water going into the tray. I cannot locate the water filter, does this model have one?
Don't know what is the model number of your fridge. 1.Need check electric water valve under the fridge. If that fridge made by GE (Kenmore just a Sears brand name and they use several others manufacturers for refrigeration), usually it's a frozen plastic water supply line inside freezer door. You could unplug fridge for 24 hours (you have to put food from freezer to other freezer).
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
We have a ge profile refrigerator and there is water leaking on the left side under the freezer. The inside of the ice tray has tan colored gunk on the ice and the bottom shelf of the freezer has a 1/2 in...
manually derfrost fridge/freezer,clean with bicarb only...... dry as best you can.(important) clean drain hose fill freezer from top with any spare space filled with foam in plastic bag(s)looks awful but works a treat (cheap too)invest in a freezer thermometer minus 20C IS BEST.....
Feb 07, 2010 | GE Profile 20.7 cu. ft. CustomStyle...
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
I possess a GE Fridge model No. PCG23NHSBFBB (2 years old)and although the water dispenser is fine, the ice maker has stopped making ice cubes (the the dispenser tray has no ice in it)
i guess the ice try is completely dry.. this tells me that your solenoid has gone. unfortunately the only way to fix it is to replace the solenoid.if its not the solenoid it will be your water pump. both will require a technician, hope this helps
Nov 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE fridge makes Ice but can't get any water?
He is saying the heater in the ice tray located on the bottom that helps loosen the ice before it is dispensed to the ice pan.
A new ice maker for your fridge can be purchase for less and you can install it yourself. Below is my site link, just put your model number in the search feature or the part number WR30X10093 of the ice maker. We also offer free help and assistance, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 28, 2009 | GE Profile PFS22 33" Artica French Door...
Ge fridge makes Ice, doesn't dispense
turn freezer side to zero for 1 minute. press water dispenser
Jan 26, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Cube dispenser does not work...
Is the ice in the bucket all frozen together as one big lump ??
Aug 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is going to dispenser in door but not to icemaker.
The first thing I would look at is the two solenoids on back of refrigerator. Each of the two have 2 wires. Switch the two sets of the two and then try the water dispenser. If the dispenser then don't work the ice maker should begin filling. If this happens you will need to purchase a new duel solenoid for that fridge. Hope this helps, Sea Breeze
Oct 28, 2007 | GE Profile PSI23NCR Side by Side...
Refrigerators Logo
87 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
