Question about Bowflex TC1000 Treadclimber
Bowflex tc 1000 treadclimber
I have a treadclimber tc1000 from bowflex and the treadles will not engage when turned on...replaced all the io cables and checked for voltage to the mother board....please help
  • 1 more comment
  • Anonymous Mar 18, 2014
    treadclimber TC 3000 won't go up and down
  • Anonymous Mar 19, 2014
    Looking for guidelines to help me replace the main drive motor for a TC20 Treadclimber
  • Anonymous Mar 30, 2014
    The treadles on my bowflex TC fall hard. How do I fix that?
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
    Problem Solver:
  • 6 Answers
I have a TC3000. Did you try recalibrating the machine? See the owner's manual for directions. Perhaps this will work.
Posted on Jul 29, 2009
Tread climber starts up and shuts down in a few seconds. Starts clicking
Bowflex Treadclimber Shuts down - Questions - Fixya
www.fixya.com > Forum > Treadmills > Bowflex > Bowflex Treadclimber
Bowflex Treadclimber, shuts down related issues. ... After a few times of shutting down due to the heat. Ad ... It shuts down about 60 seconds after it starts.
Customer Reviews: Bowflex TC3000 Treadclimber
www.amazon.com/Bowflex...Treadclimber/.../B000B...
Amazon.com, Inc.The second time I used it I slowed down the speed and worked on getting the ... After researching the TreadClimber for over a year (the cost was a big factor .... We were never able to make the treadles go up and down more that a few inches. ..... a great workout However it continually shut offs while working out and Bowflex ...
Comments for Bowflex TreadClimber Problems
www.treadmilltalk.com/bowflex-treadclimber-user-comments-comments....
Oct 30, 2013 - NOTE: My comment about Bowflex Treadclimbers is also one I left in another area. ... seems like no one sprung the extra few bucks to pay for someone to put the ... In my case , after the initial startup, the machine stops EVERY time at ...nearly spine snapping shutdown at exactly 32 minutes after starting. 5.
[PDF]Bowflex® TreadClimber® 1000, 3000 & 5000 - Nautilus
download.dfxi.com/.../SM/Bowflex/BFX_TC135_SM_RevA_web.pdf
Jan 27, 2016 | Bowflex TreadClimber TC10
Do i need a safety key to start the tc1000
Yes, it will not operate without the yellow safety key inserted into the console.
Dec 15, 2012 | Bowflex TC1000 Treadclimber
My treadclimber is stuck on a high incline?
This is the nature of the treadclimber, the decks are inclined until you step on them. In use they should drop with your footfalls to absorb the impact, then rise back up as your foot nears the rear of each treadle. If you would like more travel as you walk turn the dials on the shocks to a higher setting, for less travel turn to a lower setting.
Sep 10, 2012 | Bowflex TC1000 Treadclimber
My Bowflex treadclimber Tc1000, the belts won't move, everything else is working
Motor may be disconnected or defective. Contact Bowflex for troubleshooting assistance, or they can provide an electronic copy of a service manual with troubleshooting steps.
Aug 08, 2012 | Bowflex TC1000 Treadclimber
TC1000 when turned on runs at high speed only has no display and no control
Your motor control board sound defective, there is likely some debris or liquid that has shorted out the contacts. Contact Bowflex for replacement.
Aug 09, 2011 | Bowflex TC1000 Treadclimber
Our TC 1000 stopped. We get the Error Code E1 when we try to turn it on. There is no sound or any movement. I don't know where to start. Help.
hi
ur treadmills speed sensor have some problem. pullout it clean it and then refix it. also check its white connector , is its connection is proper or not. if the sensor found faulty replace it.
ok
Dec 20, 2010 | Bowflex TC1000 Treadclimber
Bowflex TC 1000 treadclimber causing power surges that freeze the cable and internet and change the time on 1 alarm clock for 1-2 minutes every time I turn it on. What's causing this?
You are not on a dedicated circuit the amp draw must be significant thus pulling down the voltage causing your grief. Find a and outlet that is not on the same circuit your electronic units maybe in another part of the house. Or put in a new circuit if you have a vacant in the breaker box, but that need a qualified electricians to do the job$$$$$
Jul 10, 2010 | Bowflex TC1000 Treadclimber
My bowflex treadclimber goes slow/fast/slow again and stops. It then shows an E1 on the display. What can I do to fix this? I have no directions for trouble shooting. Also, should I be able to speed...
The speed sensor is not connected correctly. There should be a jumper wire that runs from the speed sensor over to a harness by the control board on the other side of the machine. There may be a second jumper wire connected to nothing, only used in the 3000/5000 models. There is also a wire that comes from inside the treadles that isn't used on the 1000. The current assembly manual available from bowflex online seems to explain it better.
Oct 26, 2009 | Bowflex TC1000 Treadclimber
Bowflex Treadclimber tc 1000 turns off
Problem could be low colant, water pump, fan not kicking on (bad sen or bad fan motor) radiator dirty,
so the Treadclimber not working properly.
I hope this helps u
Thanks for using FixYa.
Jan 29, 2009 | Bowflex Treadclimber
Bowflex Treadclimber tc 1000 turning off
Napa 8300 silicone. Spray on each walk deck under the belts. just a quick shot from front to back in a fluid motion. test unit and see if it still shuts down.
Bowflex TC1000 Treadclimber Logo
949 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
