HaroWikihttp://www.harowiki.com > serial-number
The Haro Serial number page will help you decode, or try to figure out the model of your Haro bike. The serial numbers change from the 90s, 2000, and so on.
Missing: ACAllHO1239 ' Show results with: ACAllHO1239
1979
On Marlins made from 1948 and later, subtract the 1st two digits of the serial number from 2000.
Serial number 21615408
1st two digits = 21
2000-21 = 1979
Print Shop version 21 Deluxe is not compatible with Windows 7. You have to use a newer version 23 which is compatible. This is due to software compatibility with Windows 7.
You can check forcompatibilites issues @ Windows 7 "software & hardware" compatibility center
Hello Friend,
This version is not supported by Vista, you have to upgrade it to "The Print Shop® Pro Publisher™ Deluxe 22 " version.
Visit the link below for more details:
Solution You must reinstall Microsoft .net framework.
You can do this by: Go to the control panel Go to add remove program select Microsoft .netframework 1.1 and remove Also if you have the Microsoft .netframework 1.1 Hotfix select that and click remove as well.
Once both those are removed we can reinstall Microsoft .netframework from the Print Shop Install disc
You can do this by: Insert the Print Shop Install disc Double Click on My computer Right Click on the Drive that contains the Print Shop Disc Left click the open option. Double click on the folder called Setup Double click on the file that’s called 1033DotNetfx This will reinstall the net framework on your computer and it should fix the issue you are having.
I have not used Print Shop in years but i always was able to save to a file then save it to a disc using cd writing software. Just take notice of where your files are being saved. I think you can use the save as function and choose a spot to save it for easy retrivial then close the print shop and open up cd writing software and save the project to a disc.
