Question about Poulan Pro 22" Self Propelled High Wheel Mower
Plug fouling - Poulan Pro 22" Self Propelled High Wheel Mower
  • panilling9
    panilling9 May 11, 2010
    L19LM at .030 gap setting?
  • 420 Answers
Make sure the air cleaner is clean.
Posted on Aug 28, 2009
Rear spark plug bank is fouled. The 3 in front are fine. What cold be the problem?
I am assuming it is oil fouled rather than fuel fouled. Oil fouling is usually due to valve stem seal leakage. Most engines have the oil return on the cylinder head at the rear. When the engine is shut off, some oil pools at the rear of the head. If the valve guide seals are worn, then the oil will leak around the stem of the #4 valve and eventually foul the plug. If there are no real issues with the engine other than this one, it is usually best to keep a clean plug or two available and swap out the plug periodically when fouling is detected. Then clean the fouled one and keep for reuse later. If it is happening too often, getting the cylinder head reconditioned is a good idea.
Oct 09, 2015 | 2006 Acura MDX Touring
One plug foul after 200 miles runs ruff
the next time it fouls check the plug when you take it out, if it is covered with oil then you may have a broken ring on the cylinder that is allowing oil to pass through to the combustion chamber and fouling the plug. Or the valves pay be letting oil drain in past the valve seats.
Jul 04, 2012 | Chevrolet Caprice Classic Cars & Trucks
Scott, 95 GMC 5.7L keeps fouling plugs
Hi Dale,
Several factors can contribute to spark plug fouling:
- The air/fuel ratio may be too rich as a result of incorrect carburetor adjustment or a poorly performing fuel injection system.
- Worn piston rings or valve seals may allow too much oil to leak into the combustion chamber, leading to oil fouling.
- The ignition system may not be performing properly.
- Prolonged idling or continuous low-speed driving may keep the spark plug from reaching its optimum operating temperature. Using too cold a spark plug can lead to the same problem.
- A dirty air cleaner can create a too-rich condition which can lead to fouling.
Have each of the above checked and corrected.
Fuel, oil and carbon fouling can all be the result of different causes but, once a spark plug is fouled, it will not provide adequate voltage to the firing tip and that cylinder will not fire properly.
In many cases, the spark plug cannot be cleaned sufficiently to restore normal operation. Hence, I always recommend that a plug be replace, once it becomes fouled.
Cheers,
Scott
"If this has helped you in any way, please be kind enough to rate this solution"
Nov 02, 2011 | 1995 Chevrolet K1500
95 GMC 5.7l keeps fouling plugs
Hi Dale,
Cheers,
Scott
Help with 76 ironhead 1000 fouls plugs when it get hot and it wont charge
Ok, you have two problems. Fouling plugs and charging system problems. Work with one problem at the time. I'd work on the plug fouling problem first. What is fouling the plugs? Is it oil or gasoline fouling the plugs. Take one of the fouled plugs out and smell of it. Is it gasoline or oil fouling the plugs? If its gasoline, you have a problem with the carburetor. In this case, I'd need to know what kind of carb is on the engine. Is it the original Keihin or has someone put an aftermarket carb on the engine? Do you know how to check the jet sizes in the carb? If it's oil fouling, is it due to valve guides or rings? Does the engine smoke from the tailpipes? What color is the smoke? Black or blue smoke is caused by a too rich fuel air mixture. White smoke is oil burring.
As for your charging system, the first thing to do it to polarize the generator by momentarily shorting the positive battery post with the armature of the generator. If the generator still does not charge, you need to check the brushes in the generator and the output of the generator.
Good Luck
Steve
Jun 13, 2011 | Harley Davidson XLH 1000 Sportster...
Can a fouled plug be cleaned and if with what product
It can be cleaned and you must use a sand blaster (by far the best way to clean them) that is just for spark plugs. Another method is to use a wire brush and carburetor spray cleaned. Below is a link to the spark plug sand blaster i mentioned.
http://www.sears.com/shc/s/p_10153_12605_SPM211697464P?sid=IDx20101019x00001a&ci_src=14110944&ci_sku=SPM211697464
Apr 26, 2011 | 1997 GMC Yukon
One plug is constantly fouling
If you're running the correct spark plug, you need to determine what is fouling the plug. Is it gas fouling or oil fouling? If it's gas fouling, what type of fuel delivery system is on the bike, carburator or fuel injection? If it's oil fouling, there could be a broken ring in that cylinder or a bad valve guide or seal.
Oct 15, 2009 | 2003 Harley Davidson FXDL Dyna Low Rider
Failed spark coils on my 1999 Lexus ES 300. Replaced one last March and two more last month. I read that fouled plugs could cause coil failure. Since the recommended schedule for ''hard driving...
exposure to heat, weather,salt in winter and water make them more susceptible to failure I would change them knowing that my others failed
Aug 25, 2009 | 1999 Lexus ES 300
Cyl#3&5 foul plugs 97 suburban good compression all cyl new cap rotor distributor wires plugs module
Fouling occurs when the spark plugs' firing tip becomes coated with excessive fuel, oil, or combustion deposits so that it is unable to produce a spark. A plug can become fouled from continuous low speed driving, improper spark plug heat range (too cold), improper timing (over-retarded), too rich an air/fuel ratio or an oil leak into the combustion chamber. A variety of self-cleaning features are designed into most plugs to reduce fouling.
Jul 17, 2009 | 1999 Daewoo Nubira
I have a 99 Ford Explorer V-6, Automatic 4-wheel drive. I recently had a fouled plug and it missed for 2 or 3 weeks. I had the oil changed and was told that there was gas in the oil pan could the fouled...
its not totally abnormal to have gas in oil, fouled plug could have contributed to this as with a fouled plug some gas is not being combusted, however if the fouled plug was replaced and veh is running corrected i wouldnt worry bout it good luck billy
Apr 07, 2009 | Spark Plugs BR4HS Plug 10/BX #3322
Poulan Pro 22" Self Propelled High Wheel Mower Logo
52 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
