Question about Saws
Mastercraft 14-in. Chop Saw w/ Laser fuse problem
My mastercraft metal 14 inch cutoff saw model number 55-6848-8 stops almost immediately after beginning a cut...any suggestions on how to fix this? How do I replace the fuse?
    Scholar:
  • 173 Answers
The fuse is more than likely, fine.
Instead, check the carbon brushes.
Once you have dis-assembled the unit, you will see the way the springs hold them in.
If you can't find the brushes, chances are, they've desintagrated into micron thick diamonds.
(Unfortunately, they're worthless diamonds lol)
Hope that helps the problem.
Posted on Jul 24, 2009
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
Can i cut metal with this saw
Please share the make and model of the saw, however, the cutting of metal depends largely on the kind of blade.
Metal cutting blades have both a different "set" of teeth and number of teeth per square inch.
You will also be getting different teeth for different kinds of, and thickness of, metals.
By and large, the thinner the metal, the more teeth per inch.
Your motor speed will also affect how well your machine will cut metal.
God bless your efforts.
Jan 25, 2016 | Saws
What is the best band saw blade for cutting metal
Hey , I read this blog and it helped me a lot in choosing the correct saw blade in my cutting application. This might help you .
http://bandsawblog.com/choosing-the-right-blade-for-your-cutting-application/
Try checking this site : sawblade.com . :) Hope this will help you .
jack
Nov 07, 2012 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Cut off saw stopped working cord has power could it be bushings?
more likely it is the brushes, there should be two plastic plugs on the side of the motor case with slots for a screwdriver. remove the plugs and take the brushes out. they should have a replacement number on them if not the user manual may list them
Sep 25, 2011 | Craftsman 14 in CutOff Saw
Model #55-6848-8 14 inch metal cut off saw. purchased at Canadian tire corp. this saw sits for long periods of time in between uses.it is still in brand new condition. the saw worked a-1 for the first two...
It is simple to fix this. Take out the switch and open the switch. The contacts are stuck. It takes little to open the contacts. You may need to smooth contacts off with emery paper. It need to do the same. It works fine after. The difficult thing is to open the handle and get the switch out.
Apr 26, 2011 | RTO UST 14-inch Metal Cut-off Saw
When re-sawing 10 inch by 4 quarter oak, the cut is a curved cut, not a straight cut. What is the cause?
Alot of things could be going on, the best advice is to go to youtube and find "the wood whisperer" he has a video on just this. It helped me
Oct 14, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
My drop saw runs at 5000 rpm .most 14" discs are only rated to 4400 rpm. Are there 14"discs rated at over 5000rpms
go 2 home depot and buy Norton brand blades a lot of blade suppliers are putting a pic of cutoff saw on the blade itself 2 tell u its 5400 rated home depot and Norton r the cheapest and lasting
Jun 29, 2010 | RTO 20 14" Abrasive Chop Saw Blades Metal...
Mastercraft Maximum Compound Mitre Saw
built by canadain tire company their customer service number is 1-866-746-7287 they should be able to get u replacement part and or advise who in ur area can
Jan 25, 2010 | Saws
Saws Logo
592 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
