Question about Coleman Cable Power Inverter PMP1200
Red light goes on and it beeps
We have a coleman 2000 inverter on our boat it is hooked into a bank of 4 batteries, i have a feeling one of the batteries in the bank may be bad but have not put a tester on it yet
2 Suggested Answers
  • 10 Answers
SOURCE: I went to hook up the inverter to the battery and
If you are asking if this was the correct polarity, then no. In A/C wiring the black wire is hot, which is sometimes the source of confusion. So...
D/C (Direct Current, found in your car)
Red = Positive (+)
Black = Negative (-)
A/C (Alternating Current, found in your house)
White = Common
Black = Hot
Green(or solid copper wire) = Ground
If you have already hooked up your inverter the wrong way, you've most likely fried it. If it is still okay, then you've got yourself a good unit.
Posted on Aug 08, 2009
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
I was given a coleman Powermate 400 watt inverter I hooked it up to a car battery and the fault light immediately started flashing I do not have a manual based off this being given to me.
I'm sure you can easily get a PDF manual on-line somewhere.
My guess is that sometimes these inverters will give an error if you do not have something plugged in creating an electrical draw
Mar 02, 2016 | Coleman Electrical Supplies
I have a Minn Kota MK 460 on board charger that the number 1 red light is on and it is not charging that battery. When you hook up to the other 2 batteries the light still continues to stay on. I had the...
is this a 3 or 4 bank charger I had the same problem but my battery was bad if you don't have the charger on the battery it goes to you will have a red light if your battery are hooked in series to check your charger disconnect the cross over wire and put charger on battery see if red light goes out if so you have charger on wrong battery or you have a bad temp.sencer in charger cord on # 1 feed
Sep 26, 2013 | Boating
Hooking up a 36 volt charger to three 12 volt batteries in series
first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
Aug 29, 2013 | Minn Kota Boating
Have a coleman 2000 watt 24v dc power inverter. When using it for a short period the temperature light and alarm sounds. The can just be a tv. The watt meter on the panel don't event light up. What the...
If you are only tring to run a TV off this inverter, it appears you may have a defective unit. If you have had this inverter for only a short time, contact the dealer/store where you bought it and seek their advice. If you have had it for 90 days or more you can still contact the dealer, but maybe it would be best to contact the coleman company. You can go to their website nad find out how to contact the division that deals with this particular type of product.
Mar 23, 2011 | Coleman Cable Coleman 1000 Watt Power...
I attach my inverter with custom battery cables and it powers up. As soon as I plug in an extension cord (any cord)it starts beeping. I don't even have anything plugged into the other end.
please check the voltage of the battery may be the voltage of battery is low or use the multi meter and check DC volts before conneceting the battery and after conneceting once more check the DC volts it could slove the problem
the beeping sound is due to battery low voltage
what is the DC input of the Inverter check the battery hook up if the inverter is of example DC 24 volts please check what is the input
Nov 17, 2009 | Coleman Cable Power Inverter PMP1200
Boat battery charging issue
Hook up a differant bank and see if it says charged, check volts of battery must read 12.6 volts to be fully charged. If it dont bad battery
Jim OMC Retired Mech
Jul 01, 2009 | Boating
I have no instalation instructions for my 2500 rppipower inverter
You should use 2 red and 2 black cables, Install the inverter as close to the batteries as possible and use minimum #4ga cables #2 are better. Keep the cables as short as possible. You will need also connectors, like the ones on the truck's battery cables, attach these to both ends of each cable and crimp VERY well, connect all 4 cables to the inverter first, then the red cables at the positive battery terminals (if 4 batteries use one on each end) then the black cables to the negative posts the same way.
Jan 07, 2009 | RoadPro AC/DC Power Inverter 2000/5000w
Coleman Cable Power Inverter PMP1200 Logo
81 people viewed this question
Top Coleman Cable Electronics - Others Experts
Are you a Coleman Cable Electronics - Other Expert? Answer questions, earn points and help others
