Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Dryer tries to start but drum wont turn
Maytag LSE7800ACL Dryer tries to start but wont turn, Should I be able to turn the drum by hand?
  • 1,056 Answers
You can turn it by hand but make sure it is unplugged!!
Posted on Jun 28, 2009
Maytag ensignia dryer drum not turning
The belt would be the first thing I would check sounds like it may have broke off.
Here is a link for parts and other causes. Maytag Dryer Drum Not Turning
Jul 14, 2016 | Maytag Dryers
My Maytag Performa Dryer model PYG3360AWW wont turn on it just buzzes when I push the start button. what do I do to fix it?
See if you can turn the drum by hand, there should be some resistance. If its locked you will need to disassembly the dryer and see what is binding. If everything(motor,rollers,pullys)spins freely they you most likely have a faulty motor winding and will need to replace it.
Dec 21, 2014 | Maytag Dryers
My dryer wont start. When i turn the button to start it, it hums but wont run.
something is jamming the drum of the dryer from turning... remove the casing and take a closer look. There may also have been something recently dried which may have come out and jammed the dryer drum. Try hand turning the dryer drum to see... it should freely revolve at least a little bit
Good luck with it
Ck
Feb 13, 2011 | GE DVL223EBWW Electric Dryer
When push the start button you just hear a hum, the drum wont turn, now if you reach inside you can turn it by hand, the belt seems to be intact
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 20, 2010 | Maytag PYE2300AY Electric Dryer
I have a Maytag Electric Dryer #sde2606ayw, when i push the button it makes humming noise but wont start, i can turn the drum by hand so i dont think the engine is frozen. Could this be a belt problem?
no thats wrong even if you can start it up by hand the motor can still be bad period. if there is no response and all relays test good behind the control panel cover then it is indeed ur motor. cha ching if u call a repair person.
Jul 29, 2010 | Maytag SDE2606 Electric Dryer
Maytag dryer makes rumbling noise when drum starts and again when
Sounds like a broken spring or a spring mount.
Jan 17, 2010 | Maytag Dryers
My maytag dryer won't start. When I push the start button it makes a "errrrrrr" sound but won't start. Any ideas?
Stuck drum or failing motor. Try turning the drum by hand. It should move fairly effortless in one of the directions. If it does - the problem is in the motor. If it does not rotate - check if something is stuck between the drum and rear or front panel. Good luck Motor part number is 31001589. Replacing it is fairly hard for untrained.
Nov 26, 2009 | Maytag PYE2300AY Electric Dryer
Doesn't start and cannot turn drum with hand
Although Maytag dryers are not one of my specialities, I am inclined to think that your problem is being caused by the start capacitor, which I am sure is fitted to m
Dec 21, 2008 | Dryers
Wont spin or drain
The drain pump is jammed or clogged up. Remove the filter cover and check for bobby pins, coins or bra wires. If clean, remove drum to pump hose from the pump and check for any foreign matter. Try to turn the pump impeller by hand. It should turn freely. If pump is not free, replace it.
Nov 03, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
220 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
