Question about Danby Compact Refrigerator DCR-101W
Plugged in refrigerator and it's getting really hot on side
Mini fridge for garage was unplugged to defrost, then when plugged back in it is getting extremely hot on the side while beginning to cool off. Worried it might catch on fire???
  • 585 Answers
I don't think fire is any issue. The unit cools itself by dissipating it's heat on its outside walls. For the moment, the outside is hotter than normal because the inside is also hotter than normal. Both will normalize after a while.
Posted on Jun 28, 2009
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Kenmore elite freezer/fridge hot to the touch on the front.
I recommending unplugging the fridge, taking off the back panel, and at looking in there. I was having the same symptoms, overheating panel between the doors on our side by side. Ends up that a mouse was stuck in the fan and stalled it out. Fortunately (at least so far), once I removed the mouse and plugged back in, the fan started back up.
Jun 25, 2009 | Kenmore 63893 Stainless Steel Top Freezer...
Freezer very cold fridge warm.
does the fan come on if not then the fan delay is bad
May 25, 2009 | Refrigerators
Light on in fridge but no compressor sound or clicks or fan
That dude is probably stuck in the defrost mode.
OK try this:
1. Unplug refrigerator
2. Turn Cold Control to “off (Compressor is off)
3. Plug in refrigerator
The defrost cycle has now been initiated. The DTT has a bypass/test point for diagnosis. To terminate defrost manually:
1. Unplug the refrigerator
2. Turn the cold control “on” (Compressor is on)
3. Plug in the refrigerator
The defrost cycle is terminated and refrigeration cycle resumes.
Replace the dang adaptive defrost if you cannot get any response.
May 10, 2009 | Jenn-Air JCD2389G Side by Side...
Started smoking and fan is still running but not cooling. neither
You have a bad compressor that is the only thing that will make something smoke and not let anything stay cool
Feb 08, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer drain plug
Self defrosting refrigerators as well as freezers all have a defrost drain system. This drain system can become plugged or frozen causing defrost drain water to back up into the refrigerator or freezer compartment. The water may gather under the crisper drawers on top freezer models. On side by side, bottom or stand alone freezers ice will build up in the freezer at the bottom and eventually leak out the door.
Plugged Defrost Drain - Freezer on Top (Water under the crisper drawers)
At the top of the refrigerator next to the temperature controls there usually is a cup-like part that carries the defrost drain water into a tube and out the back of the refrigerator to a defrost drain pan behind the unit. Pull the cup out of the tube and clean the cup with hot water and soap. If there is no cup, pull the refrigerator out away from the wall, go behind it and disconnect the drain tube to clear it. If the drain tube is not accessible from the back or the drain can not be cleared from there the main back panel in the freezer can be removed to access, thaw and flush out the drain under the cooling coil.
Use a turkey baster to flush HOT water into the tube to clear any obstruction. The water squirted into the tube should end up in the defrost drain pan.
If the tube will not clear with hot water try blowing it out with compressed air.
Put the cup back on and make sure it is all the way on or in the tube.
Plugged Defrost Drain - Side By Side, Bottom-Freezer Refrigerator or Stand Alone Freezer
The defrost drain pan is located at the bottom of the freezer compartment behind the back wall of the freezer. On some models, the pan is accessible without removing the back panel and others are not. After you get to the defrost drain pan use a hair dryer to melt the ice from the pan.
Once the ice is removed use a turkey baster to squirt HOT water into the drain hole to clear the drain.
When the drain is clear you should hear or see the water you are squirting into the hole enter the pan under or behind the refrigerator.
TheRepairGuru ---- www.repairclinic.com
http://www.repairclinic.com/Whirlpool-Refrigerator-Parts
Jan 26, 2009 | Whirlpool ET9FTKXK Top Freezer...
Divider red hot
"Nothing blocking the fan from moving" was it spinning?
Is it cooling in the freezer?
the compressors do get hot ..but if they are not cooling the relay could get stuck on the start windings .. you will need to replace it..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Kenmore 5842 side by side crapped out - approx. 9 years old - garage fridge
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Mar 12, 2008 | Kenmore 58422 / 58429
Fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
Sep 05, 2007 | Maytag MSD2454G Side by Side Refrigerator
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Danby Compact Refrigerator DCR-101W Logo
1,632 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
