Question about Kenmore 64802 Top Freezer Refrigerator
How do I clean the coils Model 363.9762811 Ser#L61961617
  • 585 Answers
I had just posted most of this in another response. It should help you. Remove the grille from the front of the unit beneath the doors and look at the condenser coils. Most people have no clue whatsoever that those must be cleaned periodically. If the airflow is choked off by excessive dirt, the system will overheat, and the performance suffers accordingly. Let it go too long and it's compressor time. Clean with what you have available, one of those polyester featherdusters along with a good vacuum cleaner with crevice attachment along with a dust mask for yourself is highly recommended You may also want to pull the unit away from the wall so to clean from the back as well. There should be a removable panel. While you're in there, make sure the condenser cooling fan is unobstructed and turns freely.
Posted on Jun 28, 2009
W have a amanda ref model AF12538AEW SER#12987374LX putin to storage a year ago. Worked fine. Pulled it out of storage. Freezer get 34deg. Ref 40 deg. Any thought whats wrong?
THE UNIT HAS MOLD BUILD UP IN THE EVAP COIL IT NEEDS TO BE CLEANED PROPERLY BY REMOVING THE FREEZER RACKS AND THE SCREWS IN THE REAR OF FREEZER COMPARTMENT THEN USE HOT SOAPY WATER IN A SPRAY BOTTLE AND CLEAN THE EVAP COIL AND MAKE SURE THAT THE DRAIN TUBE ISNT CLOGGED REINSTALL PARTS THEN TURN ON BOX CHECK TEMPARATURES. FOOD AND MOLD GETS INTO THE EVAP COIL AND MOVING DOORS AND FLAPS AND AIR PASSAGES CLEAN UNIT WITH HOT WATER AND BLEACH MIXTURE TO KILL MOLD SPRAY OUT ENTIRE BOX WITH MIXTURE OF SOAP AND BLEACH WATER AND RINSE COMPLETELY
May 04, 2015 | Refrigerators
Refrigerator & freezer compartments @ 64 & 24 degrees F. respectively.condenser coil clean, however, "clean condenser coil" appears on display even after being reset. circuit board...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Sub-Zero 650 / O Bottom Freezer...
It is a Kenmore Model Number 106.9555721, Ser # SF 1216302. will not maintain temperature. Thermocouple problem? I have dropped the controls down but I don't see a thermocouple lead. Is it probable that...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 27, 2010 | Frigidaire FRS3R5EMB Side by Side...
Need to know the tonnage ofCarrier s/s Model #38ARZ008, ser # 1404G20031
Brand: CARRIER Manufacturer: CARRIER CORP SYRACUSE Model Number: 38ARZ008(5/6)0 Condenser Type: air-cooled Coil Model Number: 40RM-008--B5/6GC System Configuration: Split System Air Conditioner Energy Efficiency: 10.6 EER Cooling Capacity: 90,000 BTUs / hour ARI Type Code: RCU-A-CB Electrical Service: Triple-phase Electrical Input: 8,490 watts per hour Voltage: 230 and 208 and 460
12000 btu's per Ton, equals to 7.5 Tons.
Sep 29, 2010 | Carrier 38CKC042 Air Conditioner
My GE Artic Profile refridgerator blows warm air on both sides Model number PSS25MGNAWW SER #420869
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 17, 2010 | GE Profile Arctica 25.4 Cubic Feet...
I have cleaned the coils this morning, but the refrigerator section does not appear to cool. The freezer seems fine. This is model eti18PKXGWI ser no. 042 9086 eemingly c. 10 years old.
Your freezer fan has probably quit. On most refrigerators the freezer is the only compartment actually cooled by the compressor and coils. The refrigerator compartment is feed cold air from the freezer compartment by way of a small fan. If you have you refrigerator turned all the way up and the door open you should here the fan running and be able to feel air moving somewere in the refrigerator compartment.
Sep 05, 2010 | Whirlpool Refrigerators
Tips on how to clean the condenser coils of a maytag mzd2766
Turn off power. Water hose with sprayer. Soak the coil. Spray with 409 cleaner. Let it ser for about 10 minutes. Spray off coil from top down. Do not use to much pressure or it will bend the damage the fins. Bruch clean indoor coil with nylon brush. Your unit will last a lot longer. Rsuty
Jun 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Goodman 3 1/2 ton unit
I work for a very large reputable goodman dealer. Your equipment appears to be a correct match. The correct orfice should have been taped to the outside of the outdoor unit in a baggie right beside where the pipes connect. Things will run alot smoother though if you scrap the orfice and have a TXV installed (thermal expansion valve) . This is a mechanical device that adjusts the flow of freon into the indoor coil based on the immediate needs of the coil. After that, balancing the refrigerant is a piece of cake as all we need is about 10 degrees of subcooling to make sure we have plenty of liquid to the TXV.
Jun 08, 2008 | Heating & Cooling
Kenmore 64802 Top Freezer Refrigerator Logo
213 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
