Can 10,200BTU parts be used in 12,000BTU units?
I am needing to replace the condensor coil in my unit that I punctured this morning. I have another model, but is less BTU's. Same brand, same size, but different BTU's. Can I use the one with 10,200BTU's condensor coil in my 12,000BTU unit. Is this something that is possible to be done at home? or will I need to take it in for repair.
  • 520 Answers
Those coils are matched by tonnage and you probably arent going getting away with that but it might be close enough to try if your willing to accept the consequences that might occur.To err to the side of caution ,I would probably not advise this...This actually needs to be done by licensed individual as far as epa compliances with enviromental obligations and releasing refrigerants into the atmosphere...
Posted on Jun 28, 2009
  • 334 Answers
Hey there, you cannot interchange the coils. They are rateda t the amount of heat they reject, if you don't reject enough heat, the pressures will build and the unit will fail. You can however patch the coil where it was punctured. You can braze over the hole with silver solder or brazing rod.
seth
Refrigerant lose
YOU WILL NEED TO REPLACE THE CONDENSER COIL(HOT SIDE OR BACK OF THE UNIT) AND RECHARGE THE UNIT SAME AS IF THE UNIT HAD A REFRIGERANT LEAK.
COIL IS ABOUT $95
Feb 27, 2014 | Breezaire WKE 4000 Wine Cooler Unit - 1000...
My Window unit cools real well in the morning. The air flow from the ac is 50 degrees, then by noon the temperature is 80 degrees and then it won't cool again. I am trying to cool an 8 x 35 ft....
When was the last time you cleaned the evaportor coil and condensor coil???? When its cool outside the condensor if its plugged with dirty can mantain the right condensor Head Pressure by useing the cool outside air when it has to run with 80 to 100 degree air it can't get the head pressure with in range to cool the freon. I would clean the condensor coil.......
Jun 19, 2011 | Friedrich ZStar ZQ10A Air Conditioner
Will trying to chip away ice in the small freezer part i punctured something. How will this effect the fridge? Will the fridge still stay cool, and just the freezer part not work, or do i need to buy a...
If you've punctured a section that allows the refrigerant gas to escape, the following can happen:
1. If you switched the unit off immediately after, then the puncture can be sealed, and the unit 're-gassed'.
2. If the unit was left to run, there is a real possibility that the compressor could sieze, resulting in repair costs that would exceed replacement costs.
Jun 08, 2011 | Refrigerators
I have a 2006 Pontiac Vibe. The AC went out. When I took it to a repair shop, the guy told me that it looked like debris was puncturing the condensor. After 1 hot summer and spending $600 to replace the...
My experience with A/C Condensors is that you can take it to a Radiator Shop that welds aluminum and they can repair it by welding the hole closed. I had it done twice on my truck's condensor and it works great. To try and resolve the problem you can put some fine mesh screen in front of the condensor to keep debris from puncturing it.
May 13, 2011 | Pontiac Vibe Cars & Trucks
Sub zero 690 vacuum condensor light flashing, clean vac. condensor, light still flash after 2 days.
I assume from your post you have vacuumed the condensor at the top of the unit? Did you do this regularly over the life of the unit? You have shut the unit off for at least 5 minutes (allowing it to reset) and then turned it back on and the vac condensor light still flashes? I had this same thing happen - unfortunately for me I have had to replace the condensor twice in the 12 years I have owned the unit. Luckily first time was covered by warrantly (parts and labor). Second time was in the 11th year and the parts were covered, and the labor was covered 50% after I complained......It ended up being a leak in the sealed system (condensor). If it keeps happening you may want to call for service - could be that it just needs freon, but it could be the condensor)
Sep 08, 2010 | Sub-Zero 690 Side by Side Refrigerator
Food thawing, freezer not cold enough
There is a big list of problems that can cause this poor freezing. This model has a "never clean" condensor coil that should not need cleaning as (as most coils do neeed cleaning every +/- 2 years. Of course this never clean idea assumes certain normal circumstances. If you have extra dusty conditions or high level of dirt and air movement around the frig, then the never clean aspect may not work for you and the coil need cleaning. Alsso, can be defrost timer, can be defrost thermostat, can be defrost heater coil, can be circulating fan in rear of freezer. If you push on the back panel of the freezer compartment and hear crunching sound, then there is frost blockage on the inner coil and you have a defrost parts/control problem. You must turn off unit, remove back panel and allow frost to melt (a heat gun or hair dryer will help;never use a pick or screwdriver to jab at ice on the coil-----one slip and you can easily puncture coil and its "all over". Goodluck, Macgivor
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Punctured a hole in air condtioner..HELP
The only sure way to repair the unit is to replace the condensor coil. Pressures are too great for a patch job.
Jun 28, 2009 | Heating & Cooling
Leak repair Samsung window air conditioner
Modern window units intentionally do not allow the water to drain directly, they want the fan blade to sling the water on to the condensor (the coil that is outside) to aid in cooling actually helps the unit cool better in high outside temps, it also evaporates it this way, depending on where the hole was drilled it may be able to be repaired, if it was just a copper tube it will be less expensive than replacing the whole coil. Since its a relative inexpensive unit anyway the labor and freon may be more than its worth. Lesson learned dont drill a hole in the base it lowers it's efficiency and can lead to a punctured freon line.
Sep 29, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
