Question about Sub-Zero 690 Side by Side Refrigerator
The freezer does not maintain its temperature periodically. It will go from 0 -70, melt everything and return to 0. started last week and happens about 24-36 hours apart. Repairman (long time sub zero expert) cannot figure it out. Checked all the diagnostics tests and everything proves to be ok. The refrigerator side is perfect. Help!
  • 1 more comment
  • kellers88 Jun 28, 2009
    Thank you for the quick response. Actually, the freezer was full of food when it started (never had a problem with the freezer for the 9 years we owned it.) After the first meltdown, we emptied the freezer, it did exactly the same thing empty. Tried removing the ice maker to see if that made a difference-none!
  • kellers88 Jun 29, 2009
    Thank you. I did notice that when I close the freezer door, I hear two loud swishing sounds, sounds like the compressor. Never heard those sounds before. Could it be the compressor?
    Yes, it does has dual refrigeration systems. Door seems to be sealed properly. When the last melt down happened at 70 degrees, the surface where the door seal hits the freezer frame was incredibly hot to the touch. Almost like it was heating the freezer rather than cooling.
  • 585 Answers
Is the freezer side empty or nearly so? All modern frost-free units must go through a defrost cycle every 8-12 hours of accumulated running time. That figures out to every 20-40 hours in real life, and the box will be in defrost for maybe 15-30 minutes, depending on design. If the box is full of frozen food, the cycle goes unnoticed as you cannot freeze and thaw food that fast (the food actually keeps the compartment cold during the cycle). However, if the box is full of air, the temperature can change very rapidly. I suspect this to be your case. I am dumbfounded that your servicer didn't explain this to you.
Posted on Jun 28, 2009
  • 2 more comments
  • Bruce Volkers
    Bruce Volkers Jun 28, 2009
    You may have a failure of your defrost timer, with it getting stuck in defrost for longer than normal. That would stretch out the 15-30 minutes I indicated to a much longer timeframe.
  • Bruce Volkers
    Bruce Volkers Jun 29, 2009
    Compressor problems don't come and go. This is not likely to be a compressor problem. Is the door misaligned? not sealing consistently? Door misalignment is either worn or bent hinge, or unlevel surface where the box sits.
    When this thing thaws, any idea for how long it's in that condition at a time?
  • Bruce Volkers
    Just how big is this box? I see other postings regarding this model, I get the feeling this has two complete, separate sealed systems Is that correct?
  • Bruce Volkers
    The heater around the door prevents condensation, and subsequent mildew from forming on the door gasket. It accounts for the door seal area being 60-80 degrees hotter than the inside. Being that there's two independent systems, there's a separate thermostat for the freezer that could give trouble.
    This might be it.
    The defrost system also includes a thermo-disc type thermostat that is supposed to cut out when the evaporator reaches a given temperature. If it fails to open it will cause an uncontrolled high temperature. It is an inexpensive part and worth a try.
    Problem Solver:
  • 6 Answers
Ok, if your defrost heater is open circuit, the unit will sit doing a 'natural' defrost until the temperture rises enough to allow the defrost ntc to sense defrost, hence the defrost times longer than normal.....
Posted on Aug 01, 2009
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Whirlpool Chest Freezer Not Cooling Properly After Brown Out
work should be performed by a qualified service technician. verify that there is proper voltage at the wall outlet using a voltage meter. if it is ok check for voltage to the compressor relay. if it is ok unplug the freezer and check for continuity at the start relay and overload. if it is open you have a relay or overload. if it is ok check for the ohms rating at the compressor. common to start/common to run, start to run should be the total of both. also start/run to ground if any of these are open you have a system problem.
Apr 30, 2017 | Freezers
My side by side refrigerator on the freezer side is dripping water at the bottom on to the coil. The coil seems to be making a sizzling sound and turning red is this ok
There is a defrost heater that periodically turn on to melt the accumulated frost on the coil. The heater will warm the coil to about 45 degrees and a defrost thermostat should shut off power to the heater. The defrost cycle should only last about 30-45 minutes then the compressor should kick on. If you find that some items in your freezer are melting, or that the freezer is not maintaining temperature, then something is wrong. Hope this helps you.
May 24, 2011 | Maytag Freezers
Prep table is not cooling, fan is working, unpluged it for a half hour or so and seems to be working again but will probably stop working again, this is the second time it has happened in the last few...
Michael Youngman
Expert
Sounds like your defrost cycle has failed. Your defrost cycle is operated by a defrost timer or your motherboard depending on the age of your refrigerator. When your refrigerator goes into defrost, it turns on an electric heater that melts the ice from your coil in the freezer. When your defrost time or electric heater fails, it allows ice to build up on the coil in your freezer which blocks airflow which causes your cooling compartments to not maintain temperature. Hope this gives you an idea what to look for and a guide on where to start looking
Jan 21, 2018 | Carrier Beverage Air® SP72-18
Freezer goes off with brief power failure + does not reset
What Samsung said is untrue....
The fridge and freezer have default settings...8 and 38 deg. If it looses power and is restored it will default to that....
This fridge is a complex device and is compute chip controlled.
There are tests that you can run if you have the ability to read and follow directions....That will allow you to guide a service person to what your problem is. They will probably not have this information so I am giving you the link to the service manual...
Good luck
http://www.ajmadison.com/ajmadison/itemdocs/DA68-01778A-EN.pdf
Jan 29, 2010 | Samsung RB215LASH
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Whirlpool SD20 Freezer Intermittent Temperature Malfunction with Alarm Alert
Apologies, the above two guest comments are mine, not sure what happend!!
Oct 16, 2007 | Whirlpool S20DRSS33 Side by Side...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer defrost all. RS2556
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Jul 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
570 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
