Question about Kenwood VR-6060 6.1 Channels Receiver
I own a Kenwood vr 6060. My speakers make a poping sound when I pause the DVD player. I've tried connecting different speakers, and the problem still occurs. Is this a setting issue or a hardware problem?
  • 4,234 Answers
This is more likely a problem with the CD player, not the receiver. The CD player has what are called "muting" transistors that should prevent the creation of the "pop". Try the CD on another system. I suspect that the pop will follow the CD player. If this is the case, close this question as "solved" and post a the make and model of the CD player requesting a fix for a muting transistor problem.
Please keep us posted,
Dan
Posted on Jun 29, 2009
I have 2 good qaulity heybrook speakers and have tried everything to connect them properly such that both play sound when the tv / dvd is on. Both speakers work perfectly one at a time and both work...
You're guessing. That is exactly the wrong thing to do. Get the manual.
http://www.retrevo.com/support/Kenwood-VR-205-Receivers-manual/id/480ci174/t/2/
"[D]vd 6 channel input" is for a 6-channel analog input as the name implies. I doubt you even have a source that HAS 6 analog channel outputs.
Speakers are OUTPUTS of the amplifers' speaker posts. Any one can work ANYwhere.
And that bi-wire capability, IF the speakers have it - pretend it isn't there.
Jul 31, 2011 | Kenwood VR-205 Receiver
Have a VR-407 receiver, all of a sudden there's no audio coming out of the speakers from the TV. Also, DVD, tuner and CD player have no sounds. Speakers are only a couple years old.
Check for basic things like speakers being turned off or switched to speaker b from a and the tape monitor switch being on. Larry's Electronics.
Apr 27, 2010 | Kenwood VR-407 Receiver
Right speaker not working. Will work during test however is not working after.
When it works with only the audio test signal that is provided by the receiver and nothing else, then that indicates that the device that is connected to it that you are trying to get sound from is not functioning properly.
First however, make sure that your balance controls are properly adjusted for matched output. Then check the connection of the devices such as your DVD player, CD player etc. If you are using digital connections such as optical or coaxial, then try a different cord...they might be damaged.
Feb 12, 2010 | Kenwood VR-407 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
I have a kenwood vr-707 it gets surround sound on dvd/vcr but I can't get surround sound on just tv.
Well you have a built in decoder/surround processor that will detect a signal with the surround sound info(dvd/sat.receiver/cable converter etc.) and will then process it to the different speakers on your system. In the absence of that signal it will process it as standard stereo sound(two front speakers). You may want to look in your receiver functions/menu for simulated surround.
Hope this will help.
Nov 24, 2009 | Kenwood VR-707 Receiver
Connection problems
If the CD player has left and right outputs and the receiver has those inputs for a CD or DVD then there's a start.
Speakers...match them up to positive and negative with no power to either component.
Jun 09, 2009 | Kenwood VR-307 Receiver
Kenwood vr-405 receiver
I have the 405 as well. My TV has an optical out and I run that straight to the 405 optical input. I set the input selector to DVD/CD (not DVD)and presto! TV audio out my speakers. It all comes down to the audio connections on your TV.
Mar 23, 2009 | Kenwood VR-405 Receiver
Cant get the wiring figured out.........
I have a similar set up. For yours, I would run one optical from your Sat box to your 407 and connect the DVD player optical to the Kenwood as well. This will allow you to get whatever your watching, DVD or Satellite to your speakers. For Video, use the component cables to connect DVD player to TV. For the SAT box, coaxial to TV or S video to TV will give you about the same video quality. I hope this helps. A couple of suggestions: Your new screen size will greatly magnify the quality of your video, what looked good on the Sharp may not look good on the Samsung due to the size difference. I REALLY suggest you get a new SAT box with a HDMI connection. Also you can get a blu ray player in the $120 range. The Blu ray will play blu rays and upconvert DVDs to a higher quality picture through its HDMI connection. You will be amazed at the difference HDMI will make on how your TV will look!
Oct 29, 2008 | Kenwood VR-405 Receiver
No sound from my VR-507
My Kenwood1.gif VR-507 had been working great. I hadn't changed anything. I hadn't even moved it. It just suddenly stopped producing sound. It didn't just stop while it was on. I had turned it off and when I turned it back on, nothing. I tried running the speaker setup to see if it would output pink noise, I could hear the test sound, but I couldn't hear any audio from the TV or DVD player..
Help. :-(
Dec 14, 2007 | Kenwood VR-507 Receiver
Kenwood VR-6060 6.1 Channels Receiver Logo
274 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
