Question about ASUS A7V8X Motherboard
Hi there
i tried to turn my pc on this morning, there was a smell of burning, i check this out and found the smell coming from the PSU.
i have tried a new PSU, power led is on, hdd and power light on constant, nothing happens, the mb power led is soild green, agp led is off, all that happens is the CPU fan runs, and nothing else, no display, no post, no beeps.
no burn marks on the motherboard or PSU, removed the video card, powered on no beep, just CPU fan running and hdd and power led on constant.
i have cleared the comms by pulling out battery and doing the jumper free and jumper mode and still nothing.
i have tried to post with only the processor attached, i get no beeps.
please can someone tell me if it is likly to be mb or CPU
  • 317 Answers
When a power supply goes out the way yours did, it's going to fry the MB 99% of the time. So you're going to need a new MB. It's possible that you CPU is ok, but that could also go too. I would replace the MB first, then the CPU if that doesn't work.
Posted on Nov 07, 2007
My computer turns on, i can hear it, but the monitor displays "no signal"
Because you are getting no signal on monitor, The first check would be the VGA cable! Do you have a spare to test with?
Jan 18, 2015 | AMD Computers & Internet
I have a 2004 Pontiac Aztek that will not start
Check your starter.mine burned up and it smoked and would not start.
Oct 06, 2014 | 2004 Pontiac Aztek
I turned on my tv this morning and it started smoking and of course smelling like something inside was burning. We took off the back and can see nothing that looks burnt or melted but the tv still wont...
may be ur tvs lamp side have some problem. may be the lamp over heated and burned. just open its lamp cover ann check it.
also check its power supply input point(near fuse) there is an MOV (used for voltage surge protection) is burned or not. if there is any voltage surge it will get shorted and the fuse will blow off, protect the power supply for any further damage. check the fuse also. if found open then check the MOV. insert fuse only after replacing the MOV.
Dec 22, 2010 | Samsung HL-S5087W DLP TV
I have a acer aspire one, i bought it yesterday it worked fine, just the battery was a little low, this morning it won't come on at all, i plugged the charger to it and no lights come on nothing happens
Ok some im assuming its a laptop hence the battery first if some batteries go completly flat you will need to wait a bit while plugged in to get some energy. Secondly try plugging in elsewhere and leave for ten minutes then turn on. Thirdly if your using a powerboard ensure it hasn't tripped overnight if it has push the button or use another board. Last and a long shot check socket and plug for signs of burning/ can you smell burnt plastic?
Nov 27, 2010 | Computers & Internet
My PAC25 had a burning smell come from the unit and now when i turn it on i hear the hum of the compressor trying to turn but nothing else happens. it is a few years old and out of warranty so is there...
The burn smell is the fan motor cooking. I have the same unit and upon strip down the motors windings were fried. Now that hard part of finding a replacement.
Nov 18, 2009 | DeLonghi PAC85 Portable Air Conditioner
Compaq presario V3019US notebook pc has burning smell
Take out the battery and run just on external power, see if the smell goes away. If it does, check to see if there is a recall on that battery.
Jun 08, 2009 | Computers & Internet
Smell when unit comes on with heat
Hi!!!remember everytime you turn on yout furnace you will have a strange odor thats all the dirt that is burning from the heating element if your using the emergency heta if not the what you are smelling is your fan motor replace it and you should be fine..Good luck..
Jan 19, 2009 | Ruud Matching Split Air Conditioner
Start up
good day!
I have the same asus motherboards I check first the memory if it is clean next is battery. Try to check also the unit if it is clean.
Secondly, after doing my first suggestions if it doesn't work try to check your processor maybe the lock 4 sides are not mounted properly. resulting to sudden turning off. or sometimes electric current disturbance.
Third, Ty to check your Hard disk drive ( HDD) may be the cable connection has he problem.If you use sata try ti clean the plugs. For the IDE you may use cleaning procedures too.
Dec 19, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Do you smell anything burning. This happened to me and I cut it back on. It stayed on for 30 secs or so and did the same thing. After doing this 2-3 times, I smelled a burning. Being a member of the Fire Dept, I didn't want to see my buddy's coming to the house, so I unplugged it. The next day, I took it apart and there was a burnt resistor or something under neath the fan. I took it back and they gave me a new receiver, but I'm expecting the same with this one.
May 16, 2008 | Samsung HT-X50 System
ASUS A7V8X Motherboard Logo
140 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
