Question about Acronis True Image Home 2009 Full Version for PC
I can't get out of try and decide. When I tried
I can't get out of try and decide. When I tried to reboot, it loops through ''starting acronis loader'' and errors with program terminated code-1. I can't get into the bios to change to boot order to reload an operating system.
  • junkmail714 Jun 29, 2009
    Good evening,
    I have tried the cd with acronis rescue media, however, it does the same thing, however, I had not thought about the fact that even though its a laptop HD, the sata conectors are the same...I will report back. Thanks for your comment.
    David
    Good Morning,
    You nailed it, "who was that masked man", good job. I put the HD in my desktop ran rescue, then put it back in the laptop.
    Try and Decide obviously has a serious flaw, making it non usable, however, at least my HD is operable.
    Thanks again,
    David
    Scholar:
  • 103 Answers
Acronis has an application that run before the OS called Acronis loader. It is posible it gets corrupt. Try the booting cd with acronis rescue media. Then Uninstall the boot loader. Ultimately, if you cannot do backup/restore from the computer, extract the hard drive, using and hard disk to USB adapter, do the nessesary operations on othe computer that you will hookup the hardrive.
Posted on Jun 28, 2009
  • Juan Carlos Cabrera
    Juan Carlos Cabrera Jun 29, 2009
    Hello, Yes the SATA connections are the same, slip my mind(too much IDE Connections). On another computer where you connect the Laptop drive do a backup. When done, Format the drive and Restore the backup on the drive and re-insert on the laptop.
How do I stop my laptop from reboot loop?
Just insert a windows CD and repair your OS. Your problem will be solved while preserving all your files and folders! Good luck
Jun 14, 2013 | Acer Aspire 7520-5185 Laptop
I need acronis true image 11 home serial no
If you are installing a trial version of Acronis True Image Home 2011 or Acronis Disk Director 11 Home, you do not need a serial number.
If you have an OEM version of an Acronis product (e.g. preinstalled on your hard disk, notebook etc), please contact your OEM vendor for a serial key.
If you purchased your Acronis product online, then you should have received your serial number in an automatic E-mail that was sent to the E-mail address that you provided at the time of the purchase.
If you purchased your Acronis product offline at a retail store, then the location of the serial number depends on the package:
  • Boxed product, that consists of the CD, White CD Sleeve, Quick Start Guide. - The serial number sticker is affixed to the back of White CD Sleeve;
  • DVD Amaray Case, that consists of the CD and Quick Start Guide. - The serial number sticker is affixed inside the DVD case on right hand side. Directly above where the CD is held in place.
If you still cannot find your serial number, you can try contacting Acronis Customer Central here: http://www.acronis.com/support/index.html?ow=1
Apr 09, 2011 | Acronis True Image 11 Home: Windows
I want to upgrade my computer so I just purchased a maxtor 320 gb harddrive for my computer. I install the new harddrive and put the restore cd and choose the quick format. Computer reformat normally and...
Here are some solution that might help
Option 1 Do a fresh install, used the original Operating system CD
Option 2 Install Norton ghost 2010 or Acronis Migrate on your OLD HDD and make your new HDD as Slave then Clone your Old HDD to the new one..
i hope it help.
Jun 15, 2010 | Computers & Internet
I have a black screen, totally no display.. the power turns on. fans working...how do i solve this?
I used Acronis (Acronis true home 11) and (Disc Suite) to recover my computer's operating system,and expand its hard disc capacity.It took me 2-3weeks to get it back on line,(but I had an opratin sytem disc) Windows Vista Ultimate to reboot it with.Do you have your original start up disc ?
Feb 12, 2010 | Compaq Evo N610C Notebook
Acronis loader fatal error- I can't boot up !
if your pc starts ok with no cd in than do it like that if you see this error all the time it means your hard drive is shot, or erased, or partially erased and needs to be setup again or replaced. got nothing to do with acronis if it does this all the time even with no cd in drive.
Aug 23, 2009 | Acronis TRUE IMAGE HOME 2009 for PC
I am trying to replace hard drive with a larger one in a acer extensa 5420. Going from a 120Gb SATA (Vista pre- loaded) to a 320 GB SATA. Also having problems loading vista ultimate on new drive.
if you want you can try using acronis. its fairly simple and can handle your transition to the larger drive. are you upgrading to vista ultimate?
to handle the clone, download the acronis and it has a trial 15 day version. have a usb to sata connector available, you can pick this up for about 20 dollars at most computer places. turn on your computer normally and attach the new drive to the usb connector and let it load up in device manager. then from there load your acronis, in acronis select the tools/utilities and select clone hard drive, leave everything standard and it will start the process, it will ask you to reboot and from there clone your existing hard drive as is only on a larger partition size now. if you are comfortable with acronis you can change partition sizes if you like to suit you. what kind of problems are you having with vista ultimate?
Jul 22, 2009 | Acer Extensa 5620-4677 Notebook
Hard drive won't reboot. Stuck in a loop.
start the machine press f-8 select "safe mode" press enter run chkdisk/r
May 22, 2009 | E-Machines eMachines Desktop PC
I just downloaded the installation for my office jet 5600 all-in-one and at after rebooting it wants me to "sign up now". When I try to connect to it I get an error message and it is in a loop. I...
can you boot to safe mode?
Restart and press F8 and go into safe mode.
Once there go to START/RUN and type in msconfig and hit ENTER
Uncheck the HP start up entry. It will reference sign up or something like that.
Reboot and that loop should be gone.
Nov 19, 2008 | Office Equipment & Supplies
Seagate 320GB HD I copied an image file to it using Acronis software, and after a week or so when I rebooted I got a "Disk Read Error" an dpress Ctrl Alt Del" to restart computer.... all...
Don't worry about the size reported, 305GB is same as 320GB because 305GB = 305*1024*1024*1024 = 327491MB
Try deleting all partitions and reformatting (but do NOT choose Quick Format). Also try chkdisk /R C: to check for errors.
Aug 08, 2008 | Computers & Internet
Acronis True Image Home 2009 Full Version for PC  Logo
307 people viewed this question
Top Acronis Computers & Internet Experts
richie46
tuffbird72
Julie Clark
Julie Clark
Are you an Acronis Computer and Internet Expert? Answer questions, earn points and help others
