1992 GMC Yukon Logo
Arthur L Alexander Posted on Jun 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No air conditioning. A/C symbol on control
No air conditioning. A/C symbol on control flashes
Ronny Bennett Sr.
Level 3:
  • GMC Master 6,988 Answers
  • Posted on Jun 28, 2009
Ronny Bennett Sr.
GMC Master
Level 3:
Answers
6988
Questions
Helped
2285569
Points
21993
U may need freon look for small service port on larger ac line/hose this is where u charge system///more info e mail me at [email protected]
What does a symbol of a car with a lock on it mean on the dashboard
Use the Comment menu to add information to your question, please.
A possible dashboard symbol:
https://www.directline.com/car-cover/understanding-car-dashboard-warning-lights
"Brake system light. The first thing to do if you see this symbol glowing on the dashboard is check the handbrake hasn't been left on. ... That could relate to the worn condition of the brake pads or discs, a lack of fluid in the system or a problem with the anti-lock brakes (ABS) or stability control (ESP)."
Make, model and year of automobile.
Color of dashboard symbol or icon, and is it flashing?
S.U.V. won't drive over 25/30 came on all of the sudden? The lightning symbol is on in the dash?
Lightning symbol is an electrical indicator. Check alternator and battery to be sure they are in proper operating condition. Sounds like it's not producing enough charge to run the vehicle and all the electronics so it's cutting fire off to the engine.
Location of hazard switch cadillac 1997 sts
Just to the left of the radio and air conditioning controls. A large button in the shape of an oblong oval should be depressed.
You may or may not have the Hazard lights symbol on it, depending on the wear of the interior.
I hope this helped.
1helpful
How do I turn on my air conditioning on my 2005 caravan. I do not have an owners manual. Thank you.
Looking at your climate control panel, you should see a square button on the upper right section with a snowflake symbol on it.
Depressing this button should cause an amber LED to light when the blower fan is on, and activate the AC compressor.
You will also activate the compressor when you select defrost with the mode knob.
Don
Airbag light flashing
double check your on off control for passenger side air bag. if not that simple, get to the dealership. air bag control can be dangerous if deployed for no reason.
The buttons are worn down on the control panel for the air condition. How do I fix this?
if its the symbols on the buttons you can get a special touch up pen to fix it, or you can use the kind you write on cd's with, but if you somehow managed to wear out the buttons themselves you have to replace them with new ones
1helpful
No air conditioning, flashing climate light
You should make sure you have proper charge for sure.has your battery gone dead lately? I know on some of them digital climate controls will act exactly like this and have to be reset or go through a setup sequence.
4helpful
Airbag flashes 10 times misses a flash then repeats
Try clearing the codes & see if it returns. I do not see a code fault 10. Starts at 12.
Section 01-20B: Restraints, Passive — Supplemental Air Bag System 1995 Town Car, Crown Victoria, Grand Marquis Workshop Manual DIAGNOSIS AND TESTING Diagnostic Trouble Code Clearing Procedure to Clear Diagnostic Trouble Codes from Diagnostic Monitor Non-Volatile Random Access Memory.
Normal Operation
The air bag diagnostic monitor (14B056) continually checks the air bag system for readiness. When a fault condition is detected, the DTC associated with that fault is stored in the air bag diagnostic monitor's Non-Volatile Random Access Memory (NVRAM). After writing the DTC to NVRAM, the air bag diagnostic monitor signals the fault by flashing the appropriate diagnostic trouble code on the air bag indicator. The diagnostic trouble code written to NVRAM is permanently stored in the air bag diagnostic monitor until cleared by the diagnostic trouble code clearing procedure.
  • Upon each cycle of the ignition switch (11572) , the air bag diagnostic monitor checks for diagnostic trouble codes written in NVRAM. If any diagnostic trouble codes exist in NVRAM, the air bag diagnostic monitor will then check to see if these fault conditions are still present.
  • If the conditions of the diagnostic trouble code in NVRAM are still present, then the air bag diagnostic monitor will use the air bag indicator to flash out the diagnostic trouble code number that was written in memory.
  • If the conditions of the diagnostic trouble code are not still present (indicating an intermittent or serviced fault), the air bag diagnostic monitor will use the air bag indicator to flash out a DTC which is the sum of the diagnostic trouble code in NVRAM plus 40.
Example: Due to corrosion, high resistance develops on the driver side air bag circuit. The air bag diagnostic monitor stores a diagnostic trouble code 32 in NVRAM. Upon each cycle of the ignition switch , the air bag diagnostic monitor checks the resistance of the driver air bag circuit.
  • If the resistance is still high, the air bag diagnostic monitor causes the air bag indicator to flash out a DTC 32.
  • If the resistance falls within the normal range due to service or an intermittent condition, the air bag diagnostic monitor causes DTC 72 to be flashed on the air bag indicator.
Once a fault has been serviced, the associated diagnostic trouble code may be cleared from NVRAM. Only diagnostic trouble codes that the air bag diagnostic monitor sees as repaired or intermittent may be cleared (diagnostic trouble codes 52 and above). In no circumstances can hard fault conditions (diagnostic trouble codes 45 and below) be cleared.
  1. Follow the diagnostic procedures as outlined to service the fault condition flashing on the air bag indicator.
  1. Cycle the ignition switch to OFF and then to RUN.
  1. Observe air bag indicator prove-out (six ± two seconds) followed by diagnostic trouble code (52-85) flashing completely one time.
  1. Locate the Diagnostic "Trouble Code Clear" Connector located underneath the glove compartment (06010) containing Circuits 631 (T/R) and 57 (BK).
  1. Use a jumper wire to short Circuit 631 (T/R) to Circuit 57 (BK) or to another good ground. This short must be made after the diagnostic trouble code flashes completely one time, but before the warning light stays on continuously.
  1. Hold short until air bag diagnostic monitor tone sounds (approximately five seconds).
  1. Release short on Circuit 631 (TAN/RED STRIPE) to Circuit 57 (BLACK). This short must be released within 25 seconds after the diagnostic monitor tone sounds. Diagnostic trouble code is now cleared from NVRAM. Next highest priority diagnostic trouble code stored in NVRAM (if one exists) will begin flashing.
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
