Question about Radio Shack Pro-97 Handheld Scanner
Cant receive on my scanner
Cannot receive anything on my pro-97 and all of my frequencies are programmed in. cant even hear WX band
    Problem Solver:
  • 10 Answers
Open up the squelch
Posted on Sep 09, 2009
Cant pick up stations
Most police stations are using the new motorola trunking units, they are on encrypted custom band channels and you will not be able to hear them. All police helicopters are equipped with them. All i can hear where i live is Fire dispatch, I cant even hear the fire fighters responses .
Nov 11, 2013 | Radio Shack Pro-97 Handheld Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
My pro 2018 scanner wont pick anything up where i live could there be something wrong with the scanner or do i need a better antenna i live in holmes county ohio
First try picking up the NOAA Weather broadcasts. They're transmitted on seven frequencies (162.400, 162.425, 162.450, 162.475, 162.500, 162.525, 162.550) and at least one should be active in your area. To check reception, just press the WX key on your scanner. If you can pick up one or more of the frequencies, you'll know that the scanner is functioning properly. If not, your scanner is likely in need of repairs - a questionable move due to its age.
If the scanner is functioning (receiving the weather band), try a quick RESET. use a paperclip or pen point to press the recessed RESET button on the back of the scanner.
Make sure that you have programmed local active frequencies into the scanner. For a comprehensive database, and a lot of other useful scanning information, visit:
After all of the above, if you are receiving weather but no local transmissions, I recommend that you try an external antenna.
If you need the manual for your scanner, you can download and print it, at no cost, here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Sep 28, 2010 | Radio Shack Pro-2018 Scanner
My scanner (radioshack Pro 2018) doesn't receive signals from local poloce, ambulance and so on. What do I need to do?
First, try scanning the Weather band to see if you scanner is working properly. If you don't pick up anything, your scanner likely needs some professional help. If the Weather broadcasts come in, then you just don't have the correct frequencies programmed for your local services, and it's possible that your area is using a trunked system - which your scanner is not capable of receiving. For a comprehensive database of active frequencies and systems in your area, Visit:
The site will tell you if trunking systems are in use, and it will also provide a wealth of other useful scanning info.
Bill B
Aug 10, 2010 | Radio Shack Pro-2018 Scanner
HELP
If the weather band is working, the scanner should be working. To verify operation:
- Move the MODE switch to "Scanner" and power the unit ON.
- Press the SVC button (chrome button below display).
- Press POL (chrome button below display).
- Turn the SQUELCH knob towards the left until scanning stops and you hear a hissing noise.
- Turn the SQUELCH knob towards the right slowly until scanning resumes.
If the scanner stops on anything - even noise, it's working.
To Program:
- Slide the MODE key to "Scanner."
- Power the unit ON
- Turn the SQUELCH knob to the left until you hear a hissing noise, then turn it the right - slowly - until scanning resumes.
- Press HOLD.
- Press E (PGM).
- Press 0, 1.
- Press HOLD.
- Enter your first frequency, including the decimal point (EX: 156.055).
- Press the E (PGM) key.
- Press the UP arrow (above the SCAN key). Scanner will move to channel 02.
- Enter your second frequency, including the decimal point.
You should now have two frequencies programmed. Press the SCAN key . . .
If it still will not accept programming, let me know.
BillB
Nov 07, 2009 | Uniden BC340CRS Base Scanner
I can not get any sound out of my radio shack pro 97 scanner I turn the volume all the way up and hear a light uzzin sound I have it on the weather channel and no sounds my scanner saids all channels...
Nothing's wrong. All of your frequencies have been deleted (pre-programmed PLUS anything you entered yourself).
You'll need to re-enter all of the frequencies to get it working again.
Oct 26, 2009 | Radio Shack Pro-97 Handheld Scanner
Realistic pro 2020 scanner
The Realistic PRO-2052 is an old (vintage) scanner receiver with fixed AM and FM modes on the bands it cover, as specified by the U.S. band allocation. The PRO-2020 covers only the VHF and UHF frequencies and modes AM and FM is not user selectable. Frequencies can be programmed into any of the 20 memory channels
U.S. Coverage: (varies from state to state and other countries. We don't use 30-50 Mhz here in the Philippines for 2 way mobile communications, except for cordless phones)
30-50 Mhz Lower VHF at FM narrowband only (covers mobile, emergencies, businesses, etc. and
cordless phones)
108-136 Mhz Aircraft band at AM narrowband only
138-174 Mhz Amateur and Commercial band at FM narrowband only (2 meter band)
410-512 MHz Amateur and Commercial band at FM narrowband only (70 cm band)
If you're trying to select AM or FM for a specified frequency, I'm afraid you can't do that as it is not selectable.
If you are trying to program AM Broadcast frequencies (mediumwave (MW) or FM Broadcast frequencies (FM radio stations), those were not covered by your PRO-2020's microprocessor. Even if you modify your scanner to receive those bands, you will not hear radio transmission properly since the receiver do not decode FM wideband, which is the standard mode for FM broadcast and Television band.
MANNY DE GUZMAN, JR.
SoundMagik Home Studio
Manila, Philippines
Visit my website at http://mannydeguzmanartist.wetpaint.com
My talents and modeling site at http://teenmodels2007.wetpaint.com
Jul 02, 2008 | Radio Shack Pro-2052 Scanner
Radio shack pro97
I have the same issue, was working fine, then the scan works but never stops on any freq. nor does the squelch make any sounds. The only sound is the key tones, I have reset the unit and tried new batteries and a different antena. still nothing? any ideas?
Feb 24, 2008 | Radio Shack Pro-97 Handheld Scanner
Pro-97 scanner recieving problem
try going to a urban area and scanning the NOAA band. if that works your programming is wrong and there is nothing wrong with your AM/FM base band. also the BNC antenna connector on the inside is notorious for breaking away from the board, nothing a little solder cant handle. Also make sure your local freq's are not Digital
Dec 05, 2007 | Radio Shack Pro-97 Handheld Scanner
Radio shack pro-97 hand held scanner
you can go to scanner master.com and get what frequencys you need. if this don't work let me know i will give you a new site.
Oct 31, 2007 | Icom IC-R5 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
193 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
