Question about Canon NP 6050 Copier
User Code How do I change the code for the copier?
  • 328 Answers
You may want to print this out because it is long.
Adding codes
Adding codes is really pretty simple.
First Add a System Manager code:
  • Press the 'additional functions' button to the right of the touch screen.
  • Press the 'system settings' button ON the touch screen.
  • Press the 'system manager settings' button on the touch screen.
  • Press the 'system manager' button on the touch screen and then use the touch screen to enter the system manager's name. Press 'done' when you have finished.
  • Press the 'system manager id' button on the touch screen and use the numeric keypad located to the right of the touch screen to create the id.
  • Press the 'system password' button on the touch screen and enter a numeric password for the system manager. YOU SHOULD MAKE A NOTE OF THE SYSTEM MANAGER ID AND PASSWORD, AS THIS WILL BE NEEDED TO CHANGE SETTINGSLATER.
  • Press 'next' on the touch screen.
  • Press 'email address' to add an email address for the system manager.
  • Press 'contact information' to add an extension to reach the system manager at.
  • Press 'ok' to complete the process.
  • Press 'done'.
Next add user codes:
  • Press 'system settings' button on the touch screen.
  • Press 'department id management' on the touch screen.
  • Press the 'on button' on the touch screen.
  • Press the 'store dept. id / password' button on the touch screen.
  • Press 'store' on the touch screen.
  • Press 'department id' on the touch screen and then enter a numeric code using the keypad.
  • If you want additional security you can also set up a password by pressing 'password' on the touch screen and, using the numeric keypad again, enter the password. The password can be left blank if desired.
  • Additionally you can set an impression limit for that user by pressing 'impression limit' on the touch screen.
  • Press 'ok' on the touch screen to add the user.
  • If you wish to limit impressions then you must press the 'limit impress.' Button on the touch screen.
  • If you want to add more users at this time go back to step 6.
  • Press the 'done' button.
  • Press the 'off' button at the bottom of the touch screen next to 'accept jobs with unknown id.
  • Click 'ok' to complete the process and start using the copier or go back to step 5 to add more users.
After this process users will have to enter a user id to use the machine. At the end of the copying process users should press the 'id' key located at the bottom right of the keypad to logout. The machine will automatically log users out if there has been no activity for a few minutes and this can be changed by pressing 'timer settings' in the additional functions.
While this seems like a lot it actually doesn't take very long to do. There is a far more elegant set of instructions in the 'reference guide' that came with the machine, which includes pictures, and starts on page 4-2.
Posted on Nov 07, 2007
Kyocera maintance code 1087 1087 .
Press 1087, 1087 until the machine shows U000 self status, press 163, press start and then scroll to execute and then press enter. the machine will iunitialize and come ready for copying
Oct 19, 2012 | Copystar Office Equipment & Supplies
How do you change cleaning web
Why do you want to change the cleaning web? That error code is a laser problem. The cleaning web would be a E0005 code
Aug 16, 2012 | Canon CLC 1140 Copier
How can i change the department code in toshiba estudi 455 series copier
Press the Counter button --> Department Management --> Password --> "123456" (default) --> Department Registration --> Select old dept code--> Change
Mar 06, 2011 | Toshiba e-studio 455 Copier
I need a reset code for maintances on a toshiba estudio 350
Hi how are you this is jack... jack_pak@hotmail.com
Dear you need PM maintances code..
ON the machine 08 mode and change the 251 value.
Change or Zero. ok .Then you change This value your copier finished Maintenance Indecation.
PLEASE VOTE ME.
Thanks.
Best Regards,
Aug 14, 2010 | Toshiba e-Studio 350 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
I have a AR-M237 small copier and I need to put in some new account codes and delete some old account codes. I have a manual but it doesn't seem to tell me how to accomplish this. Please help.
You need to have the ADMIN code to access, change, edit, delete or install new codes. Look in the Management setting under user tools. Look for user codes or key operator codes. Defualt ADMIN code is normally 000000 or 11111, that is if the ADMIN code was not changed.
Dec 18, 2008 | Sharp AR-M237 Copier
Savin 2545 copier error code sc541
Hit the yellow botton ( Reset/ CA), then 1 then 0 then7 , then hold down the (Stop) botton till the display changes... Then turn the copier "OFF" then "ON" it may clear the code. The code has to do with your fixing unit.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Change copy code
Larry, that depends on which model copier you have.
In order to help you I need the model #
such as FP7735 Dp150 D350 etc.
May 02, 2008 | Panasonic FP-7750 Black and White Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
Changing Security Code
pleaz see the operating manual ,main code is 00000
Aug 02, 2007 | Sharp AR-M237 Copier
Canon NP 6050 Copier Logo
613 people viewed this question
old marine
old marine
