I have a sharp home theater system ht x1 and when the volume reaches over 20 when playing cd, radio or dvd it shuts off and shows a "protect" error message.
  • 10,594 Answers
Home theater or amplifier has inbuilt protection circuit to monitor output signal of amplifier as well as speaker impedance that are hooked with amplifier. If any problem occurs, protection will activate and shut down amplifier to avoid further damage (or expected damage) in amplifier and speakers, same time display error code as Protect.
In this Sharp HT-X1 system, one of speakers is defective and causing Protect activation because home theater is working up to 20 volume level.
Please unhook all connected speakers with system, turn on and increase volume level and monitor does it go to protect mode? If yes, them amplifier has internal problem like dry solder joints in amplifier output section etc.
If amplifier stays OK then lower the volume, hook one speaker at a time to test protect error, found good, unhook it and put other speaker until you see protect error with any specific speaker that is bad.
Hope above info would help you to diagnose problem.
let me know further question, if any.
Thanks.
Posted on Jun 28, 2009
Mi HOME THEATER WITH DVD HT-X1 dice protect y se apaga
Mi HOME THEATER WITH DVD HT-X1 dice protect y se apaga. q debo hacer
Jan 04, 2012 | Sharp HT-X1 System
How do I shut of the Protection on the Samsumg HT TP-33 in order to play a DVD
If you mean the unit is self protecting due to a short or overload, disconenct all the speakers and see if that helps, then troubleshoot the cause. Otherwise, it needs service.
http://www.retrevo.com/support/Samsung-HT-TP33-Home-Theater-Systems-manual/id/357dj788/t/2/
Then there's this....
Copy Protection
Many DVD discs are encoded with copy protection. Because of this, you should only connect
your DVD player directly to your TV, not to a VCR. Connecting to a VCR results in a distorted picture
from copy-protected DVD discs.
• This product incorporates copyright protection technology that is protected by methods claims of certain
U.S. patents and other intellectual property rights owned by Macrovision Corporation and other rights
owners. Use of this copyright protection technology must be authorized by Macrovision Corporation, and
is intended for home and other limited viewing uses only unless otherwise authorized by Macrovision
Corporation. Reverse engineering or disassembly is prohibited.
Dec 26, 2010 | Samsung HT-TP33 Theater System
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Problem with SAMSUNG HT-X20!!
The fan is going bad and when u play dvd's the spining of the cd is acting as a fan witch is why they play longer then any other mode i had the same problem 2 times the second time samsung wanted 160$!!! thats bull because it keeps going out so what u do is open the case and remove the cover over all the capaciters and whatnot and replace that fan in the back then cut a hole in the top of the metal case directly about the cap's that warm up and install a aditional fan to act as a chimney a little noisy but i did this and the player had been runing in aux and radio mode for a few days stright now no problems at all it's alot of work and skill but for 2 5-15 dolar fans sure beats the 160 for repair or buying a new recever!
Nov 11, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Displays Protect
Hi All,
Just found this, hope it helps.
Sharp DVD Micro Theater System XL-DV60 solution Posted by sonny.marquez on Nov 21st, 2008 at 11:46pm
I own a similar system that began to have a "protect" error message when I crank up the volume. Before you proceed, the solution requires you to open up your system by removing the top cover via removal of five screws and opening it up. So IF you are not experienced in opening up electronic equipment I suggest you find somebody who does. The error is caused by the cooling fan being stuck or not able to spin. The system has a sensor wherein, when it detects that the "amplifier" IC heats up, it spins up the fan to cool it down. IF the system detects that the fan is not spinning during the cooling phase, it will give out the "protect" message. Note that it will only spin when you crank up the volume. Less or 0 volume will shut down the fan due to it's "energy star" feature.
To solve the problem, I cleaned out the dust in the system via a 1 inch wide paint brush (haven't tried the compressed bottled air used to clean computers BUT it might do) and nudged the fan. Played the system w/o a cover and observed the fan operation and so far it has solved the issue. I plan to lubricate the fan shaft with very small amount(less than a drop) of machine oil using a syringe. If it doe not work, I plan to see if I could purchase a replacement motor for the fan...
hope this helps....
Apr 16, 2008 | Sharp XL-DV60 System
PROTECTION
See my post "HT-DB120 - PROTECTION due to shorted output stage "
Jan 02, 2007 | Samsung HT-DB120 System
74 people viewed this question
 Grubhead
Grubhead
