A/c motor is running, but no cool air is coming out?
    Sergeant:
    Champion:
  • 235 Answers
The compressor clutch might not be engaging to start the compressor. Check to see if the compressor comes on after you turn the a/c switch on. Check your a/c relay to see if it has continuity.
Posted on Jun 28, 2009
Why my 2006 nissan maxima cooling fan wont come on
Defective fan thermostat, fan motor, or the engine is cool enough that the fan need not run.
Bypass the switch and place 12 voltes directly to fan motor to see if it will run.
Oct 21, 2014 | Air Cool Dryers
We have a 2002 Chevy Malibu.. And the fans want run to keep the motor cool.. When the motor get too hot the car will shut off.. So, what do I do about it??
First check fuses, there are two fans if fitted with air con. The air con. fan only comes on with the air con. The engine radiator cooling fan comes on at operation tem., it is controlled by a censer switch on the radiator .If there is power to the switch and the switch is OK the fan motor is at fault.
Aug 10, 2014 | Cars & Trucks
Engine runs hot after a few minutes of running the car
That is very vague. Have you checked the radiator, and when it is hot does the electric cooling fan come on? Try running the A/C and see if the cooling fan comes on. Does it run hot on the highway or just in city traffic? I need some more details to try and narrow it down. There are many things it could be. Low coolant, stuck thermostat, air in the cooling system, bad fan motor, fan motor relay (also known as fan switch), or temp sensor.
Jul 17, 2011 | 2000 Oldsmobile Intrigue
The air comes on and blows, but the fan outside doesn't spin....tho the air feels a bit cool, the apt never cools off
hello, if the compressor is running and yet the condenser fan motor is not most likely you have a bad capacitor to the fan or if it's a dual capcitor the fan side is bad. Another possibility is the motor itself could be shot but you would need a meter to check. with the power turned off and take you meter and put one meter lead to the ( common) wire and take the other meter lead to each additional wire coming from the motor one at a time, if you dont have resistance between any of the wires then the motor has a open winding and should be replaced.
Apr 26, 2011 | Weather King 10AJA2501AH Air Conditioner
RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
May 17, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
Motor still runs after cool air stops coming out
See if helping the fan turn will get it going thrn let it run awhile.. The fan motors rake a set if not used often enough.
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Goldstar model number wg1205r AIR CONDITIONER, NOT COOLING
thermal relay is not functioning , u need service technician
May 15, 2009 | Heating & Cooling
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
