Question about Ford 8n,9n,2n, Tractor Starter With Drive
No spark for 2n tractor put on a new 12 coil changed points and condersor was runing before i burned out 6 v coil
  • Keith Parker May 11, 2010
    Has the tractor been converted over to a 12 volt system????
  • 202 Answers
Check the resistor mounted on the back side of the dash, resistor dead no spark. you can strap it with wire to see if it fires, dont run it this way.
Posted on Jul 09, 2009
No spark at points
Sounds to me, if no spark to points I would suspect the coil.
Jul 06, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Do not have spark on plugs
You need to check the spark plug wires. Check the continuity with an ohm meter if you have one. Rule of thumb is 10000 ohms resistance for every 12 inches of wire. Also make sure to check the coil as well. This should be located at the other end of the spark plug wires. Hope this helps and good luck.
Jan 19, 2014 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 9n converted to 12 volt alt still 6 volts at dis. runs rough till i jump 12 volts to coil and then it runs good. Will this damage coil and points?
If you are doing 6 Volts at the distributor you must either have Resistor wiring or a separate resistor in the system. They make both 6Volt and identical 12Volt coils for your unit.
You will eventually burn up a 6Volt coil if you use 12Volts on it. There is an aftermarket company which has Antique supplies. Carpenter(Maybe John) has supplies for Tractors, cars and trucks that are earlier models.
Do a Web search using his name and marry it to Tractor parts, etc.
Sep 09, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 9N problems; Changed plugs, wires, cap, rotor, points, and ignition coil. Point gap at .015, new condensor. 6 V battery fully charged. No voltage drop to ignition coil. Results, no spark.
You might check ground. some of these units were ground positive. did you switch the posts?This would cause problems since the electrons are on the inside of the condinser.
Good luck
Joe
Feb 11, 2011 | Ford 8n,9n,2n, Tractor Starter With Drive
1940 9n will not start, have replaced the points, condensor, 12 v coil, wires, new carb and the stark plugs. The only thing happening is gas coming out of the itake from the air cleaner. Also I replaced...
Is it cranking? Is there a spark? If there is no spark. I would look at the points again; unless you mean you replaced them now instead of in the fall. Look at the points and if they look frosted then try sanding them or replace them again. They can go bad quickly if there is moisture in the cap. Recheck the gap. It is possible that you got a bad condensor if the points are good. Check the cap and rotor for corrosion and remove this coorosion or replace them. Check that you have voltage at the coil. It might be a bad ignition switch. If all this is good turn the crank till the points close, turn the key on and check for a spark with the coil wire within a 1/4" of a ground when you open the points with a screwdriver. If it has spark; try spraying a little starting fluid into the carb. Let us know what you find out.
Feb 15, 2010 | Ford 8n,9n,2n, Tractor Starter With Drive
Not getting spark all the time after putting new
Clean the points with an emery board if this doesn't fix it roll the motor until the points are open then short them with a screwdriver if it arcs see if the coil is putting out spark if not get a new coil
Dec 01, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
My 2n tractor only puts out 3-4 charging. The
The 12 v conversion is the way to go. 6 v is a pain. It's getting harder and harder to get parts, and running off of battery power leaves a lot to be desired, especially if you've ever had to haul a dead battery back to the barn. I had a Farmall model "B", 1947, 6 volts. 12 volts was like a whole different tractor. Just my humble opinion!
Best regards, --W/D--
Aug 18, 2009 | Ford 2n, 9n, 8n Tractor Left Taillight...
No spark at spark plug center of Coil
2000 ford escort ZX2. 4cyl . No spark at the spark plug. Wires are good.
Jul 23, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford 8n,9n,2n,  Tractor Starter With Drive Logo
400 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
