Question about Canon imageCLASS D661 Digital Printer
Black line on copy while using paper feeder
All of a sudden, all copies run through the paper feeder have a sold black line on the right side of the paper. The line does not appear when a copy is made by placing the original on the glass. Any suggestions?
  • mikeo Nov 09, 2007
    I have the exact same problem which first arose when the feeder jamed. Hope someone can help. Copies are fine on glass; solid black vertical line only occurs when using the doc. feeder. So it's not the cart. or drum. Thanks
  • Anonymous Mar 26, 2014
    I have been copying onto paper that has a logo imprinted on it (on the top, the side where I
    copy). Now sometimes a "ghost" of the logo appears on my copies.- though the "ghost" does not appear in the exact same location on the page as the logo. Any ideas?
Try cleaning the feeder glass
Posted on Dec 04, 2007
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
Black line scan
Open the scanner lid and clean the narrow glass in the left-hand part of the scanning area. Look for remains from ink or corrector at the far end and wipe them out. The narrow glass should be entirely clear to make good copies from the feeder.
Jan 09, 2014 | Canon Pixma MX410 All-In-One Printer
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
It works great in all aspects, but when I make a copy of something there is a black line about 2.5" from right side of paper (only when I use the auto feeder to copy) If I lift the lid and palce the paper...
You need to lift the document feeder and clean the small **** exposure glass located to the left of the main exposure glass.Any foreign substance on this glass(ink, glue, correction fluid,etc.)will cause lines on copies when you use the feeder.
Oct 08, 2009 | Samsung SCX-4725FN All-In-One Laser...
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Black line on copies from feeder only
you've spilled some cartridge ink on the
FEEDER ROLLS, or in the PAPER PATH... Run a few double sided test patterns, problem will do its own housekeeping... Be more careful with handling your INK CARTRIDGES !!!
Jan 13, 2009 | HP Officejet 5780 Printer
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Lines through copies
The scan glass is dirty or it has a scratch on it. It can be a small dot of ball point pen ink. A small ball of tape adhesive. A is not always easy to see. Clean it with a good solvent.
Also if the ADF feeder tray is out of adjustment, it could be caused by the edge of the paper.
Nov 01, 2007 | Office Equipment & Supplies
Canon imageCLASS D661 Digital Printer Logo
803 people viewed this question
old marine
old marine
