Sunpentown WA-1220E Portable Air Conditioner
Problem for Sunpentown WA-1220E Portable Air Conditioner
My Sunpentown WA-1220E portable air conditioner is
By raley613 on Jun 28, 2009
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Solution #1
posted on Jun 28, 2009
Not Rated)
daddyo742001
Rank: Wiz
Rating: 84%, 27 votes
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Was this helpful?
Yes
No
Popular Solutions for Sunpentown WA-1220E Portable
Questions and Unsolved Problems for Sunpentown WA-1220E Portable
Do you recommend Sunpentown WA-1220E Portable Air Conditioner?
Answer
Answer
Gas heat does not always come on when it is switched on, when it does it works fine when it does... (More)
Answer
I have an Amana Gas Fired Furnace Model CCA24FCC. It recently started blowing cold air out of the... (More)
Answer
portable sunpentown air conditioner/heater blows non heated or cooled air. after cleaning coils, red... (More)
Answer
my power light is flashing. and the unit won't come on what can I do?
Answer
I have an SPT WA-1220E Portable A/C unit that is leaking when running. It will auto shut off when it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sunpentown WA-1220E Portable...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
