SOURCE: lost 18V AC adaptor- can I use one made for laptop with 18V output?
I don't know if I would try this or not. there could be a difference in the amps and usually a charger is designed to shut off or go to trickle when the battery is fully charged.
SOURCE: my chuck wont open on my KD574CRE Black &
Try putting a vise grip on the bit,, and a big vise grip or chanel lock wrench on the key lock..
That should break it free..
Good luck..
SOURCE: Circuit diagram for charger for Black & Decker
You can contact a Dewalt Service Center to see if they have the diagram. Black and Decker is Dewalts lower priced line. A quick search on their website did not reveal anything. They may not have the diagram. As far as I know there are no parts available for the chargers so you may have a hard time locating the diagram. Try giving Dewalt a call.
SOURCE: I have a Black & Decker 18V cordless drill
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
