Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
WD Passport 250GB External Hard Drive with slow write speed
I recently decided to start using the Time Machine on my MacBook Pro, and in order to do so needed to reformat the WD Passport I've been using as a go-between for the last year or so. (Model Number isĀ (WD2500XMS-00), if it makes a difference.) In the past, I've uploaded huge amounts of data before (Last I remember was 50 or so Gigabytes, which I know didn't take nearly as long as it's been running now...) and it's never been this... slow. It had no problems reading; It copied 56 Gigs in 90 minutes to the computer, so I could re-format the drive itself. However, when I began the system backup... Something seemed off. Almost 4 hours later and it's only managed to write 12 Gigs of the 125 I need to the Passport. I'm wondering if this is a sign of something wrong with it, or I've just been oblivious before.
joecoolvette
  • 5660 Answers
SOURCE: malfunctioning WD passport that windows doesn't detect.
Inside the case is a regular laptop size harddrive.
Laptop harddrives are 2.5 inches across. (2-1/2 inches. Desktop harddrives are 3.5 inches)
I would suggest the external enclosure the harddrive is in, is defunct.
I would suggest buying a new external enclosure, and putting this harddrive in it. Then just plug the USB cable in, (As you did before), and download your data, to be ready to transfer.
You need an external enclosure that is Sata, and is for a 2.5 inch harddrive. These are relatively inexpensive.
Let me show you some examples:
1.http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2783&name=2.5-eSATA-Hard-Drive-Enclosure&Nav=|c:2781|&Sort=0&Recs=10
Posted on May 10, 2009
Crankstart
  • 696 Answers
SOURCE: WD Passport plugged into mac then PC, but no drive letter
Hi
You can either format the drive using the PC or install MacDisk on your PC witch will allow you to view any Mac formatted drive on the PC.
http://siteadvisor.de/sites/macdisk.com/downloads/17329989/
Click the link to download macdisk7.5.7.5 or reformat the drive to NTFS which the mac and PC will be able to share if the need arises in the future.
Chris
Posted on Jul 09, 2009
danikress
  • 35 Answers
SOURCE: WD Passport Drive running SLOWWWWW on time machine
USB s slow and when you have huge files it tends to bog it down. it is better to have a firewire transfer. another reason could be your computer is doing to much. leave the computer at one task. walk away and let it work. otherwise you will be using memory.
Posted on Oct 01, 2009
  • 16 Answers
SOURCE: xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
Posted on May 03, 2010
  • 94 Answers
SOURCE: wd passport not working
I am sorry to say this but by the sound of it you have accidentally reformatted your drive. The only thing you could do at this point is to try to recover your lost data which I'm afraid my not be able to be recovered depending on if the drive is solid state or not and if it has encryption on it. My suggestion is to try and recover your data using a data recover tool such as helix.
I hope this has helped.
Thank you,
Norse
Posted on Jul 02, 2010
Drive does not appear on macbook pro
You need either need a driver to detect the hard disk or you will have to format hd.
Jul 25, 2014 | Western Digital WD Elements Portable...
I am trying to back up my MacBook pro via the wd software and my external harddrive keeps on shutting down by itself. By that I mean the light on the harddrive goes out. I the try the same thing on the...
There is a WD utility that controls the drive setup. One thing it controls is the sleep time. This sounds like what you are seeing. I know the default sleep or hibernate time is annoyingly short. All you need to do is run the utility look for the sleep time and change it to a much longer period. I don't think it can actually be disabled but you can set it to an hour or so.
Sep 21, 2011 | Western Digital 1TB My Passport Essential...
Install USB 250GB External Hard Drive
Heres what to do.
1st go to this link ------ > Click Here
Next step is to choose your product type.
After choosing your product just click on the link WD SES DRIVER to download the driver of your product.
after downloading it, install it in your pc.
After installing the PC, insert your WD PASSPORT 250GB External hard drive to test if the driver you download works.
Goodluck. Hope my solution will help you. Please give me feedback regarding my solution on your problem. Thank you very much.
Jul 02, 2011 | Western Digital WD Passport 250GB Portable...
Oct 01, 2009 | Western Digital WD Passport 250GB Portable...
Local disk error WD My Passport 250GB
Do you connect & disconnect the drive according to WD's recommendations here? Try another cable. (If yours was wearing out, that might explain why it only connected some times.) Try another usb port. Check the power supply (another receptacle) Unplug other usb devices from the system.
See this article. Good luck!
Aug 18, 2009 | Western Digital WD Passport 250GB Portable...
WD Passport 250GB External cannot be recognized.
Go to BIOS (Press DEL or F2 to enter BIOS). Check if the Power state is in S1. Ensure that USB setting is in Hi-Speed.
Restart the computer and try using the device. this should fix. Let us know the result.
Thanx
Jan 16, 2009 | Western Digital Passport WDXML800UE...
WD My Passport Essential 250GB USB2.0 is not working in WIn 98SE
Try using a Usb 2 cable "The one that came with the WD My Passport " And put it directly to the PC...
In some cases, Like mine, I used an extended cable + the cable that came with the "WD My Passport" and i got the same problem ..
So i simply removed the extended cable and put the put "WD My Passport " directly to the PC with its own cable and the problem was solved to me ..
Samer.F
Dec 26, 2008 | Western Digital WD Passport 250GB Portable...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
1,104 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
