Back to:
Tags:
Heaters
Generic problem for all Heaters
HFH442 not heating after spark
posted by redrummy on Nov 07, 2007
I had my model #HFH442 running yesterday when I saw it spark inside - I immediately shut it off. When I turn it on now it doesn't feel warm - only a slight lukewarm feel on HIGH.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 10, 2007
Thanks for Trying (70)
Buffalo12980
Rank:Wiz Wiz
Rating: 84%, 822 votes
there are four deep hidden screws on the back. more than likely they are phillips head type. a number 2 phillips will fit them. remove the screws and pull off the back. the element connections are push on spade connectors. see if one of your came off. just push it back on its terminal and it should work.
Rating Locked! (?) redrummy has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on HFH442 not heating after spark:
I don't want to Accept this solution
Can you Help with these Heaters problems?
Rinnai Toyostove Direct Vent Heater:...
my stove keeps going to error code 6 and 2. what does that...
Heaters
How serious is a crack in the heat exchanger ? How much to...
Heaters
I can't adjust the heater to go on when the temperature...
Coleman Propane Forced Air Heater...
I have a rottisere grill that uses an electronic ignition...
Leisure SPC-54 Patio Heater
I purchase a All-Pro SPC_54 patio heater this summer. Used...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
