Question about Ryobi Garden
WHAT ARE THE CARBURETOR SETTINGS FOR A RYAN/IDC 284-2 STRING TRIMMER? MY TRIMMER STALLS WHEN I INCREASE THE THROTTLE. THANK YOU.
  • panilling9
    panilling9 May 11, 2010
    if you havent turned the adjustments yet find the adjustment marked L on the carb.and turn it ccw 1/8 turn and retry your throttle inital settings for a walbro is1and1/4 turn out from seated lightly clockwise they both will need tweeking from here H and L or maybe not?
3 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Posted on Jun 08, 2009
  • 708 Answers
SOURCE: What are the H/L throttle settings for a Ryan/IDC 284 string trimmer from the seated position
Normally on most older trimmers you would back each out 1 1/2 turn, hopefully it will start then adj. Your H for max rpm before going other way then adj. Your L until you can get it to rev up with no or very little hesitation. You may then have to set your H for max rev or best when the engine actually sounds more like growl than scream.
Posted on Sep 04, 2017
Sep 04, 2017 | Garden
Ryobi s430 will idle but will stall out when throttle opens. This carburetor has one idle adjustment screw and one fuel mixture screw.
Those carbs are a pain. Try arousing the idle screw, turun it to the right, then try to see if it will idle. You will have to tinker with the adjustment screw and the idle screw. Eventually you're gonna need a new carburetor. You can rebuild it, BUT , chances are those cheap carburetors never are the same.
Sep 13, 2015 | Ryobi Garden
Will idle but stalls on acceleration
to much air getting through
being careful not to over tighten or you will crack your inlet manifold
solution: tighten down your carburetor and tune up your carburetor
adjust the outside screw first that is your throttle screw
then once a full revs adjust the inside screw to where you want the max revs to be
Apr 01, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Setting the rpm
To identify the idle screw adjustment push in and and out with the gas throttle handle and look at the carburetor for a little finger that moves in unison with your movements. That finger comes to rest against a tapered screw - the latter is the idle adjustment. Clockwise increases the speed and vice versa. Adjust so unit runs smoothly at low speed - too slow and it will stall. Experiment.
Nov 22, 2013 | Craftsman 25cc Gas Line Trimmer
My curved shaft trimmer starts okay, but will only run at a little more than an idle and stalls when I pull the throttle open or have a full open choke. Any ideas?
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 22, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Will not idle
May be time to get the carburetor rebuilt. Sounds like the diaphragms are not working properly to pump fuel. You may need some lubrication on the throttle cable too. A little lubrication on the throttle arm would not hurt.
Good Day.
Oct 14, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Need to locate a muffler for Ryan string trimmer.
First they were IDC, then Ryan, then Ryobi. Now MTD owns them and sell them under Troy Bilt, Bolens and Yard Machines. Same ju.... well, never mind. An MTD dealer should be able to get one for you.
Jun 30, 2009 | Garden
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troybilt TB75SS String Trimmer will only run choked to partially choked. I can throttle it and it runs rough but will accelerate with about 1/4 choke. less than that it dies. Not much smoke I expect I...
It sounds like your carburetor needs a good cleaning. You must disassemble the carb., clean all the ports with a small Den Tech Brush, (used for cleaning between teeth). They are very small and perfect for this job. You will also want to clean the small screen in the carb. It may be so clogged that it may need to be replaced. If this is the case, you will need a carb.kit for your Troybilt Trimmer; it comes with small parts and gaskets. (It will come with some gaskets that you will not need.) Replace all old parts with the new ones. This should fix your problem.
May 22, 2009 | Troy -Bilt String Trimmer/Blower...
Garden Logo
316 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
