Question about Kenmore 44102 Front Load Washer
Brown spots appear on clothes washed in the whites cycle regardless of water temperature or use of detergent or fabric softener. Spots do NOT appear on other cycles regardless of the same variables. Spots are identical in size to the holes in the drum. Does not appear to be a mold problem as there is no smell and washing twice with Affresh did nothing to solve the problem. There is also no residue on the interior of the drum.
  • 2 more comments
  • petebran Jul 01, 2009
    Regarding your suggestion that this is a bearing problem, another expert has told me that if it was the bearing then the stain would be yellow-greenish and appear in every cycle, not just the fast-spinning whites cycle (when clothes are literally sucked into the little holes in the drum where they pick up the brownish substance that I first mentioned). Would you not agree?
    P.S. I assume my Frigidaire GLTF1040ASO is identical to a Kenmore 44102 and that's why my question is categorized under the latter heading?
    I clicked on the link but it took me to a web site (www.geecustoms.comuf.com) that was under construction and had no information.
  • petebran Jul 02, 2009
    Can anyone tell me the source of - and solution for - this problem?
    Genius:
  • 1,847 Answers
Sounds like the inner part of the the washer has rusted out causing the stains.
it can be removed with a Rust Remover. So i think you should remove the clothes as soon as the cycle is completed . If you removed them immediately they would be fine . Have your washer checked out? I think this will help you.
Thanks .
Kevin
Posted on Jul 02, 2009
  • 221 Answers
This happens becouse of bearing. As bearing has small amount of oil inside when bearing worns oil starts to escape from the bearing itself, and because of warm temperatures around the drum and the vibration when drum is spinning small particles of oil gets mixed with the water and stays on the washing load after drained out. So the best solution on this occasion is just to replace the drum bearing with new one and everything will be back to normal. Be advised: after replacing the bearing run the machine for one washing cycle without any load (no clothes). This will completely clean up the system, so will prevent from any oil that might be left in the system to get on your clothes.
Best of luck
Posted on Jun 28, 2009
Fisher Paykell washer left black grease spots on some clothes
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus
detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
The problem is the wash comes out with brown flecks all over it. I have taken out the agitator and cleaned it, this hasn't changed the result, still brown flecks all over wash
9.1 Creasing
9.2 Soiling
than soft water.
9.3 Linting
9.7 Dye Transfer
9.8 Tangling
Jun 14, 2012 | Fisher and Paykel IWL12 Top Load Washer
Brown dirt spots on some clothes after washing. similar to the wholes in the washer
What you probably have is a build-up of scrud in the machine as a result of an interaction between the fabric softener and the detergent. This flakes off and marks the clothing.
Buy a commercially available cleaner for your machine for this purpose of do one or two cycles using a bottle of white vinegar in the tub without detergent. Clean the machine out doing another cycle using baking soda directly in the drum. Repeat this process if there are still any indications of scrud.
Take care that you use the correct amount of detergent in your machine according to load and water level and do a cleaning run about every 25 wash cycles to clear away any excess detergent that was not caught by the rinse.
May 06, 2011 | Washing Machines
I purchased the Kenmore Elite washer approximately five years ago. I have had no problems with it operating. However, since purchasing this washer I have ruined almost everything white I owned and avoid...
There has been many reports of complaints regarding this problem and it was found out that the gray spots on white clothing are caused by the fabric softener. The Kenmore Elite is a "highly efficient" machine that it uses very minimal amount water when washing and rinsing. The minimal use of water results in the fabric softener not being diluted completely and eventually makes gray spots on white clothing. The ridiculous solution to this problem, as Sears "advised" is not using fabric softener for white clothing. But you may also try putting the fabric softener in a small plastic bowl just enough to hold it and place it inside the machine prior to the final rinse. Using only the suggested amount of detergent and avoiding the use of detergent powder with speckles reduces the possibility spot occurrences in your while clothing.
Aug 27, 2010 | Kenmore Elite 45986 Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Nov 13, 2009 | Maytag Washing Machines
Greasy looking spots on clothing after washing/drying.
Without seeing the spots, this is a bit speculative, but here goes,......
I'm guessing that the spots are only found on the front side, primarily of shirts, or blouses, etc. These are from grease splatters from cooking, which many times only show up after washing and drying.
The soap releases some dirt, which is attracted to the non-removed grease spot, allowing it to show up. Re-wash the clothing, pre-spotting those areas with a citrus pre-spotter.
Aug 31, 2009 | LG WM0642H
My clothes are being stained by brown/black marks. I think it is an oil leak into the drum. Is it a seal and is it easy to fix? Frigidaire Gallery Model # FWT647GHSO
Spots on clothing in a washer are usually caused by a reaction between detergent and fabric softeners, but to check and see if these spots are petroleum based (oil), try removing the spots with solvent. If the spots will come out with solvent, but not with soap and water, then it could be transmission oil that is leaking into the tub and this is very bad news. This was a common problem on the older GE and Hotpoint washers. Sorry to hear about the problem that you are having and I hope this helped. Best wishes.
Aug 02, 2009 | Washing Machines
Leaving dirty marks on clothing
Try removing the water hoses and find the screens in each end.. If clogged with gunk - that could be the culpret..
Jul 23, 2009 | Washing Machines
Oil Like Stains on Clothes
possibility is that the bearing seal is breaking down and oil from the bearings reaching the clothes. if so, the bearings will shortly follow. not an easy job and you are faced with a bill if i'm right
May 11, 2007 | Kenmore 45081 Front Load Washer / Dryer
Kenmore 44102 Front Load Washer Logo
110 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
