Question about Refrigerators
Water dripping from top of fridge
Same problem described in previous post. Water is dripping from the freezer into the fridge
    Problem Solver:
  • 19 Answers
Remove the back panel of the freezer at the bottom you will see a drain hole....this is where the water is supposed to go when the freezer defrosts itself..its going to be solid ice heat up some water almost boiling and pour it into the hole until it starts to drain...
Posted on Jun 29, 2009
Got water dripping into fridge from "vent" from
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
There is water dripping into fridge from just below the freezer, freezer is cold and fridge is cold but watr dripping.
you have a clogged drain hose you need to take out the back cover in the freezer and with a turkey baster and out water you will need to defrost the drin hose
Apr 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping into the fridge and freezing
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jul 18, 2010 | Kenmore 74262 / 74264 / 74269 Top Freezer...
I have a lg fridge/freezer and water flows from the bottom of the freezer in two channels. What is causing water to flow? Bottom draw of freezer is frozen to the floor of the freezer compartment. Help...
You have a blocked drain hole at the bottom of the fridge put very warm water in the the drawers and remove once they un thaw then remove them and clean the drain hole in the bottom. If you need more help just post here and I will give you more informaion, also if it's got a lot of water you will have to remove the drip pan and drain it out
Aug 26, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Water dripping within the fridge
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Jul 18, 2009 | Refrigerators
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Hi, I can help you. The drain is plugged in the freezer section. Could I get the model #?
Some models need an after market drain heat strip added.
Please let me know and I can get you through tis.
Thanks
Vic
May 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool Fridge makes a loud dripping sound all the time G56SHE
Erin,
The water you hear sounds like it's coming from the automatic defroster in the freezer compartment. It runs down a drain tube into the pan you describe under the fridge. The pan is heated and evaporates the water.
Just some possible explanations if you are hearing "lots" of water"
* You may be in a warmer, more humid climate
* The temperature and humidity in your dwelling is elevated
* The door gasket on the freezer may be leaking
* The freezer is too full
* The freezer door is not closing properly
* The freezer door is being left open for extended periods
* There is a problem with the defrost cycle
If you are hearing water running all the time, check the ice maker water line and fill valve (if you have an ice maker) - there could be a leak or other malfunction.
Apr 15, 2009 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
