Mondeo mk3 central locking works ok with keyfob but only locks drivers door with key also deadlock doesnt work with keyfob or key.
SOURCE: Central Locking to Ford Focus LX 2001
Problem with 2001 1.6 Focus which i was going to purchase for the wife, but problem with central locking! key fob totally dead even when i tried the reprogramming trick (key in ignition press button several times) and when locking/unlocking manually, central locking only working intermittently! Please help regards steve
SOURCE: Power door locks will not lock
check master door switch/grounds and out put power= if all ok then look at GEM module.
SOURCE: 1999 Ford Explorer Door Locks
Unfortunately, This is a very common problem with Ford Explorers! Ford replaces the locks when it encounters this issue. I managed to unseize my passanger door and tailgate lock, but the drivers door lock is broken beyond repair. You can purchase new remotes for your explorer and program them very easily. Just google ford key fobs...
SOURCE: 2000 Ford Focus automatic door locks quit working.
check fuse 63 first.
Visual Inspection Chart
Mechanical
Electrical
It could also be your GEM (generic electronic module) which is expensive as it controls a lot of stuff. A scan tool can be used to cehck for fault codes from the GEM.
SOURCE: Ford mondeo 02plt. Central locking fault
Hi I have a Toyota Avensis 4d saloon 2.0 TD 1998 R reg the problem i have is the central locking does not work it stopped working after a heavy frost
