The problem started with a sock in the pump. Pulled it out but now will only drain when I tilt the washer backwards. Did I damage the pump pulling the sock out? (Model # TAWX700JQ1). Thanks, Don
Hey Don, If you removed the cabinet to get to your pump, you had to unplug the wire that connects to your lid switch. Did you make sure to plug the lid switch plug back into it's plug-in on top of your cabinet under control panel when you re-installed the cabinet. Your washer won't spin or pump water if this is the case. I'd check that first, then check the lid switch itself for proper operation. Happy to help, Tim. please don't forget to rate my help. Thanks.
the washer tub is tilted forward causing the water to run onto the floor while filling. How do i...
(More)
the washer tub is tilted forward causing the water to run onto the floor while filling. How do i remove tub and what part do i need?
my estate washer MOD TAWX700PQ0 turned on and filled with water, then stopped working. I tried to...
(More)
my estate washer MOD TAWX700PQ0 turned on and filled with water, then stopped working. I tried to push the knob in and then pull it back out but all it did was make an err sound. What is the issue?
the washer makes a loud scrape-scrap-scrape sound when the pump runs....but it pumps the water...
(More)
the washer makes a loud scrape-scrap-scrape sound when the pump runs....but it pumps the water out... it doesn't have anything 'stuck' in the mechanisms... what could it be?
My estate washer is leaking water and oi from somewhere underneath? what could be wrong? Is there...
(More)
My estate washer is leaking water and oi from somewhere underneath? what could be wrong? Is there something I should check?
