Question about LG Flatron L1750S 17" LCD Monitor
Unlock loc 917Sw - LG Flatron L1750S 17" LCD Monitor
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 | Ovens
My fridgidaire affinity dryer has loc error and will not let me start it
The control is locked to avoid having someone accidentally start or stop the dryer. Press and hold the Options and Select buttons for 10 seconds or until the "LOC" on the display is cleared. Locking the control is done the same way it is unlocked.
Mar 04, 2011 | Dryers
Push any button and 'loc' flashes seems to be locked out
Press Options and Select at the same time and hold for 10 seconds or until "LOC" is no longer displayed to unlock the controls. Press and hold the same buttons for 10 seconds until "LOC" is displayed alternately with the estimated cycle time to lock the controls. Unplug the machine for at least half an hour, if pressing the buttons does unlock the controls, to forcibly reset the machine control and eliminate the possibility of an electronic glitch.
Oct 31, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer won't run. It beeps 3 times and flashes "err" and "LOC".
HI. The term"LOC" will be an indication of the "Child Locking" feature that has been activated either by mistake or intentionally. This is a safety feature to prevent unwanted starts when children are present.
To unlock the controls,press "Options and Select" at the same time and hold for 10 seconds until ”LOC” is no longer displayed.
  • NOTE_ If the release procedure doesn't unlock the unit and the letters LOC continue to appear, this will be a strong indication of a severe fault within the main control board. try to power cycle the unit if this is the case. if the power cycling doesn't produce good results, replace the main control board assembly.
Aug 14, 2010 | Frigidaire ATF6000ES Front Load Washer
When ever i try too adjust my coloul settings OSD LOCKED keep popping up and i can't make any adjustment
then press menu,+, -, select buttons of monitor simultaneusly and keep pressed untill osd menu says unlocked
Jan 13, 2010 | AOC 917Sw 19" LCD Monitor
AOC 917Sw picture at the start then black screen. Tried hooking it up to another computer and have the same problem.
Your backlight in the monitor is failing.
You can repair it but depending on where you are it may be cheaper to just buy a replacement. Parts cost can be $60-$150 plus labor.
Nov 03, 2009 | AOC 917Sw 19" LCD Monitor
Locked osd
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu. best regards
May 21, 2009 | AOC 917Sw 19" LCD Monitor
LOC Blinking
Control Lock
To avoid having someone accidentally start or stop the
washer, press Options and Select at the same time and
hold for 10 seconds until “LOC” is displayed alternately
with the estimated cycle time. To unlock the controls,
press Options and Select at the same time and hold 10
Jun 05, 2008 | Frigidaire Affinity ATF7000E Front Load...
LOC Error
Your child LOCk feature has been activated and will not let you do any further actions until you unLOCk it. Look in your users guide for unLOCking instructions.
Feb 10, 2008 | Frigidaire GLEQ2152ES Electric Dryer
LG Flatron L1750S 17" LCD Monitor Logo
46 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
