Question about Charanga GuitarCoach Full Version for PC
MCI Error from SHOWMCIWND The Device Driver is not Ready
I also get this error message when trying to lok at the video traing in Guitar Coach. Using VIsta (I know I know) and the program is quite old. Is this overcomeable?
Mark
I also had same problem.
Go to
http://www.musiccoach.com/technical_support/errpages/mciset.htm
and install
http://www.musiccoach.com/technical_support/downloads/indeo32fix.zip
open, unzip, install "setup"
After this you can see all video.
Don't forget to set properties of file "charang guitar coach" : open with right click of mouse, open the tab "compatinbility" and set "compatibility mode to windows 98/ME or windows 95
Good playing guitar
Fausto Viegas
Posted on Aug 20, 2009
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
May 19, 2014 | Toshiba Satellite A135 Notebook
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
Mar 15, 2011 | Computers & Internet
Have received an error message MCI driver not found? What is that and how can I correct it?
This error is related to audio drivers most of the time.
Plz download audio drivers for your laptop from below link.
Assuming the OS as Windows XP.
Courtesy HP.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-46934-1&lc=en&dlc=en&cc=us&product=434623&sw_lang=&os=228
Dreamkam...
May 17, 2010 | Compaq Presario V4000 Notebook
Driver and software loaded but when I run the software it says "Device not Ready." Device manager thinks it's a "Coach" digital camera.
open device manager
start>run>devmgmt.msc>ok
rigth click on the Coach digital camera and update driver let windows search the inter net for the soft wear. if you are unable to find beter softwear try to uninstall the camara and restart your system then plug in your camara in device manager you should see it conect rigth click and update driver aviod searching your system hope this solves your fault
Dec 18, 2009 | Largan Mega 2 Digital Camera
DRivers appear to be corrupted or missing
Hardly impossible for disc drive's drivers have become corrupted unless you have had a bad attack of Viruses. Check the power and data cable. If needed use a new IDE cable. Clean the contact points of the RAM. Then try to enter the BIOS to see if it has recognized the drive! Physically lay your fingertips on that drive to determine any vibrations which is a indication that power is reaching the device. Then try using this sane drive on another PC to check if its working properly or not. Finally lok for the latest driver depending upon the model & make of your Firmware.....................sodeep
May 02, 2009 | Computers & Internet
Device not ready
CNET's review states that this camera connects to USB, but no mention is made of it being compatible with USB2. Theoretically it should be compatible since USB2 ports are supposed to be backwards compatible with USB 1.1. Yet I have other USB 1.1 devices which will cause "device not ready" error messages when I try to connect them to a USB2 port. Interestingly, the CNET article doesn't list Windows XP as a compatible OS. Another person posted that he received the same error message when trying to connect his camera to his 64-bit XP computer.
In any event, Largan's web site doesn't make any mention of them producing complete cameras -- only camera components. Perhaps their foray into the digital camera market was less than successful.
So, while this isn't truly a solution post, perhaps it may point you in the right direction as to possible causes of the device not ready error message.
Apr 20, 2009 | Largan Chameleon XP Digital Camera
Youvam not working on Presario V3000
try download this driver and put it in.Not to worry about design for HP and all stuff.Download and install
http://www.downloadsource.net/d16952/HP-Pavilion-Webcam-Driver-Windows-Vista-x32-x64/
takecare.
Jul 12, 2008 | Compaq Presario 700 470024-192 Notebook
Mp4 player
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly.
Jan 31, 2008 | Audio Players & Recorders
Charanga GuitarCoach Full Version for PC Logo
1,010 people viewed this question
Top Charanga Computers & Internet Experts
David Payne
David Payne
Are you a Charanga Computer and Internet Expert? Answer questions, earn points and help others
