Question about Blitzz Technology Wireless G BWU713 802.11g/b (892620000313)
Limited or no connectivity
I have a Blitzz Wireless G Model BWU713
54Mbps 802.11g Wireless LAN USB Adaptor
I am getting a good signal strength and the speed is very good
Activity: sent 395 and received showing 0 what could be the problem.
It showing it inquirying a ip address but when it get it, it come up saying limited or no connectivity when i unplug the router and modem it get a connect but a few minute later I lose the connect what in the world going on.
  • 59 Answers
Here is the solution just follow it and i am pretty sure it will work
http://fixmypcandmac.com/forum/viewtopic.php?f=29&t=18
Posted on Jul 15, 2009
Blitzz Netwave point usb 802.11b wireless LAN adapter
Try this site... http://list.driverguide.com/list/company2072/ It looks like the company went out of business or something, but you should be able to find the drivers you need on the page linked above.
Mar 16, 2010 | Computers & Internet
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
Installation cd/driver for wireless usb adapter for model# bwu613
I found a driver for you, link at the bottom...
Details Applies to: Blitzz BWU613B USB Wireless LAN Card Software/Application/PC Requirements: Windows XP, Windows XP, Windows 2000, Windows 98, Windows ME, Linux, Mac
Author: Blitzz Technologies
File Name: BWU613B_USB_Driver.zip
File Size: 7.51 MB Driver Date: 11/8/2003 Driver Version: ver. 1.3
http://rapidshare.com/files/273011370/BWU613B_USB_Driver.zip
Aug 29, 2009 | Dell Computers & Internet
Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Aug 20, 2009 | Samsung NC10-14GW Notebook
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
Limited connectivity within Wireless Network
reinstall ur lan drivers then contact ur service provider
Jan 09, 2009 | Microsoft Ethernet MN-120 Network Adapter
Internet Explorer cannot display the web page
Could be a vista compatibility problem.
check Linksys website for updated driver and or connection manager.
check that you still have permission in firewall.
remove the software of the usb wireless adapter,reboot ,then re install.
just a couple of thoughts
good luck
Terry
Mar 26, 2008 | Compaq Presario 5000 PC Desktop
Wireless Network?
The modern laptop and Wii will be no problem. Windows 98 will work but it can be much trickier to set up.
Parts needed
1 x Wireless Router - You can pick up a 2WIRE Router from around £20 on eBay
3 x Wireless LAN Network Adaptors - Around £20 each.
Firstly, the Router. This bit connects to your telephone line and broadcasts your broadband signal by radio and allows several computers to use one service. When you buy a router make sure it includes installation software. You can install routers without, but it's a whole lot easier if you have it.
Next you need to be able to receive the broadband radio signal on your computers and Wii.To receive the signal you need Wireless LAN Network Adaptors on each device. Network Adaptors also have software, which allows you to install the drivers needed.
Your laptop may already have a wireless adaptor built in.
You can check this by clicking
Start\Programs\Accessories\System Tools\Communications\Network Connections
Then see if a Wireless adaptor is present. If it isn't, you can install one inside the laptop by buying a laptop wireless network card. Easier, is to buy a USB Wireless LAN Network Adaptor which just plugs in to a USB socket on the laptop.
Look for LAN Network adaptors that are suitable for the Wii and a separate one suitable for Windows 98. Most will be ok for the laptop.
Install the router first. just do what the software tells you, then install the LAN adaptor drivers on each device you want networked.
Finally, make sure you secure your router signal. That stops the guy next door using your network and offers some security from hackers. Your router will include a firewall and you can set up a key code that your adaptors will need before they can connect. Unless the guy next door has the key, he won't be able to use
your network and play your MP3s...hoorah!
Follow the instructions given in the software to set up a WPA or WEP security key.
Great fun, you'll love it if you can get it all going.
Feb 24, 2008 | Computers & Internet
Blitzz Technology Wireless G BWU713 802.11g/b (892620000313) Logo
278 people viewed this question
Top Blitzz Technology Computers & Internet Experts
Michael Galve
Michael Galve
Will Halftowaite
Are you a Blitzz Technology Computer and Internet Expert? Answer questions, earn points and help others
