Question about Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver
Loud hum when Bose Companion 3 Series II speakers are turned on.
When I turn on my Bose Companion 3 Series II speakers I get a loud hum. I think it could be a wiring issue but someone else told me it could be the motherboard. I have all of the outside connections plugged in the right way and it doesn't look like any of the inside wires are frayed or cut so I can't figure out what it could be. Any help would be most appreciated!
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Posted on Nov 14, 2009
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
Get loud hum from both bose companion II speakers when i disconnect left speaker hum goes away tried most everything else thanks
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
May 23, 2011 | Bose Companion II Computer Speakers
I have a bose companion 3 series ii my base speaker has an broken audio input that i'm trying to fix can anyone help me Please!!!!
Yes you can fix it but need a soldering iron and tin and the part that will change. Get everything in radio shack or similar store. If you don't now how solderin go to this link: http://www.youtube.com/watch?v=Rm28jkKGMz4
Good luck
Dec 15, 2010 | Bose Companion 3 Series II Multimedia...
Speaker to sensitive to bits.
you can use another product with bose
Apr 09, 2010 | Bose Companion 2 Series II Multimedia...
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Not working on my hp
make sure there turned on or make sure it`s in the right AUX input
Apr 13, 2009 | Bose Companion 2 Series II Multimedia...
Loud hum with static when speakers turned on
There is def. a loose connection somewhere in your system. This is a grounding problem within the system if nothing else. Def. a "lazy" connection somewhere.
gurutim
Mar 10, 2009 | Bose Companion 3 Series II Multimedia...
Bose Companion 3 Series II Multimedia Speaker System (3-Piece) - Graphite/Silver Logo
3,660 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
