Question about Garmin nuvi 750 GPS Receiver
Never held charge more than a few seconds
Low batt indication the moment you take off charger. new machine off internet. dont like the hussle off returning it. inside while on charch measures 7 volts on batt leads.
    Brigadier General:
  • 4,090 Answers
You need a new battery This one is a dud
Posted on Jun 30, 2009
G'Day.. I have a Plega Traveller, (it no longer
Sounds like one or both of the batteries has a high internal resistance. Bad batteries, perhaps? Have you LOAD tested or tested for internal resistance? Could be why charger is shutting off so soon.
Voltage isn't the only test for these types of batteries.
Oct 24, 2013 | Health & Beauty
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
Brand new hitachi 18v, one battery charged fine the second is completely dead it was in the drill from the factory and the charger won't recognize it when attached.
I have just had a similar issue I left the drill unused for a period and when i placed it in the charger the charger showed the battery as charged after about 15 secondseconds.
Following a internet search i found a site that suggested for a imlar problem with a camera jump starting the low battery with a 9 v battery. I had a spare from the drill which was fully charged so placed a contact from + to + and - to - and held for about 2 mins. I then placed the battery back in the charger and it started charging. Running the battery down as we speak to recharge again well worth a try. If you dont have a spare maybe the 9 v would work
Sep 03, 2011 | Hitachi DV18DL 18V Liion Cordless Combi...
I have a model SE826 6/2 amp charger i just dont under stand the gage some times te needle is on the top half scale and other times it is on the bottom scale I guess i need to know what the needle is...
When the batt is very low, the needle should show high amperage flow, red zone or high number. As the charge builds up slowly in the batt, then the needle will slowly move lower or green zone as less and less is flowing into batt. As it fills, it will fill more slowly.
Sometimes when batt is very low, it may take some time for the flow to get going, so it may look low to begin with, then go higher after half to one hour. This might also indicate a battery going bad but not gone yet.
A car battery on 6 amp will take several hours to fill. On 2 amp maybe 2 - 3 days.
If you find it looks like batt is full quickly and then fails to provide enough power, it means a part of the battery is defective which is hurting all of it, and whole thing must be replaced.
May 09, 2011 | Measuring Tools & Sensors
Casio Exelim EX-Z77 battery will not charge, charger light flashes on and off.
Your battery maybe drained, you can try to leave it in charger for hours( it will take long for a drained batt to start charging) blinking led may indicate that charger is trying to supply current to batt, anyways I strongly suggest you to buy a new one
Apr 14, 2010 | Casio Exilim EX-Z77 Digital Camera
Why won't my charging light come on when I try to charge?
hi
Try to leave it on charge for a 24 hrs. If the batt gets below a certain voltage the charger will not come up to fast charge rates(light on) to prevent damage to the batt. If it does not take a charge, it is possible that it is faulty. If you have been using the batt regularly and it suddenly stopped taking a charge, it may be the charger at fault. If you you have not used the batt for a while, it may be faulty. only way to really check for sure is to try a new batt. If you have any more questions about it, just ask away. Good luck
regards
robotek
Aug 05, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Battery problems Tc 1100
When the Batt is inserted and you are on AC power do you have a lit charge light? It's the one in the center of the three at the lower right when you are in landscape mode.
If your batt is at "end of mission" (**** up) then it's ability to hold and take a charge may be very limited. Calibrating the batt might help. You will need the toaster style charger.
If this is the issue, then the charge light may only stay on for a few seconds at a time when you first attach AC power, so be watching.
I could recommend a new batt (e-bay) if thats your only trouble. Nothing lasts forever. I'm in Missouri and will calibrate your batt if you want to mark it and ship it. Let me know.
B
May 05, 2008 | Compaq tc1100 Tablet PC
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Garmin nuvi 750 GPS Receiver Logo
73 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
