I have a phillips remote. I need the code for Sylvania tv and instructions on how to do itI have a phillips remote. I need the code for Sylvania tv and instructions on how to do it
You can't post conmments that contain an email address.
Press and hold the "Code Search" button on your Philips remote until the indicator light stays on.
Press the "TV" button on the remote to set it to control the TV.
Press the "Power" button repeatedly until the TV turns off.
Press the "OK" or "Enter" button to save the code.
Manual Code Entry:
Find the code for your Sylvania TV in the Philips remote control manual. If you don't have the manual, you may be able to find it on the Philips website.
Turn on your Sylvania TV.
Press and hold the "Code Search" button on the remote until the indicator light stays on.
Enter the code using the number buttons on the remote.
Test if the remote now controls your TV. If not, repeat the process with a different code.
Try Common Codes:
Some common Sylvania TV remote codes for Philips remotes are 0810, 1684, 1886, 2183, 1081, 1172, 1196, and 2049. Try entering these codes manually.
Look in the manual of your Phillips universal remote CL035A for ther listing of TV codes, take notes of codes for Sylvania and input codes accordig to instructions of your manual. If you can locate Sylamia, follow instrucions for unspecified device. You don't have a manual?
If I understand correctly you are using a LG remote for the Sylvania Combo set?
None of these companies make those units--someone else does and puts the name on the unit----Sylvania uses different remote codes on every model (they are actually Phillips).
Most programable remotes will get you basic functions BUT WILL BE MISSING KEY FEATURES YOU WILL NEED.
You need the original remote---GOOGLE FOR A EXACT REPLACEMENT if the original is damaged or lost.
"Universal remotes" are hardly universal as you have discovered.
If those codes dont work try the last three(or four) numbers of your TV's serial number.
On my universal remote is just a matter of holding down the TV button till the light stays on, then punching in the three digit TV code. When the TV turns off it's the right code. But read your manual for your controller.
I went to Radio Shack an purchased a 15 dollar Phillips universal remote and it worked after entering one code for sylvania combo tv's. I did the Happy dance and now I can watch my tv again. ONE FOR ALL® URC6131n Universal Remote Control JiggyChic
We have a Sylvania 6313CB TV/VCR combo. I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books. So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked. This was a $6.00 universal remote named "One For All" we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on
Pushed the "VCR" button and light blinked once
Pushed and held the "set" button until it blinked twice
Released the "set" button and entered the numbers "0000"
Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
I have tried all the codes for my DVD/VCR Magnavox tv and the remote still does not work. I bought the jumbo one.
Help
Stacey
