,i reinstalled xp pro. then discovered i have no internet connection , when i check the advice manager there are 3 yellow question marks. (1) Ethernet Controller. (2) PCI Communications. (3) Universal Serial Bus (USB) Controller
    Sergeant:
    Novelist:
  • 192 Answers
Hi there.
Ok, you need access to another computer that has internet access, and either a blank cd/dvd, or a blank floppy disk.
You will need to check what Ethernet Controller you need on the other system, then do an internet search for it, or go to the manufacturer's website, inc. the the pc manuf. i.e. HP. Once you have found the file that you need, download it, but you need to Save the file to the desktop. The USB Controller can be found by downloading the motherboard/chipset drivers for that system. These will be found on the manufacturer's website, ie Foxconn, MSI, Intel, VIA or SiS. Again you will need to save the file to the desktop.
Once you have the files, copy them onto a blank disk/disc. Then put the disk/disc in the pc that needs the files and install them.
Unfortunately, this is the only way, as you have stated that you are missing both the Ethernet and USB Controllers.
If you need anymore info, I'll only be too glad to help.
Tim
Posted on Jun 28, 2009
  • 49 Answers
You will need to find out what drivers you need for your computer by checking the manual. Then download and install the drivers and you will be up and going in no time!!
Device\NTPNP_PCI0027
Troubleshooting :
Cannot access internet in OS using onboard network card bg-country_outline_top.png bg-country_outline_bottom.png Solution
1. Please check the LAN settings in BIOS.
2. Install a fresh OS and the motherboard driver, network card driver in support CD or downloaded from official website.
3. If the network card is not recognized in Device Manager, please contact reseller (service center) for tests.
4. If the network card is recognized in Device Manager, please do some troubleshooting as the following steps:
4.1. If there is yellow question mark or exclamation mark before the network card, please re-install OS and drivers. If the problem persists, please contact reseller (service center) for tests.
4.2. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection, the network cable is shown as "un-plugged(X)", please check network cable/router/switch/modem/other network peripherals and network port, or plug network cable to other system for test. If the problem persists, use another computer in the same network environment to check if it can access internet. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable.
4.3. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is disabled (grey), please enable(right click and choose "Enable") it for a test. If the problem persists, please turn off firewall, search and kill virus, reinstall OS and drivers. If the problem still exists, please contact reseller (service center) for tests.
4.4. If there is no yellow question mark or exclamation mark before the network card, but in Control Panel/Network Connections/Local Area Connection is shown as "Limited or no connectivity" (yellow exclamation mark)", please do some troubleshooting as the following steps:
4.4.1. Right click and choose "repair"
4.4.2. Unplug and re-plug the network cable
4.4.3. Re-connect the network or access IP
4.4.4. Restart
4.4.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.4.6. Skip router and connected to Modem directly
4.4.7. Turn off other computers in the same network to avoid IP conflict
4.5. If there is no yellow question mark or exclamation mark before the network card, and there is no abnormal situation in Control Panel/Network Connections/Local Area Connection, please do some troubleshooting as the following steps:
4.5.1. Try to access IP or Static IP automatically
4.5.2. Unplug and re-plug the network cable
4.5.3. Re-connect the network or access IP
4.5.4. Restart
4.5.5. Check server DHCP settings, IP configuration, seek advice from ISP
4.5.6. Turn off firewall, search and kill the virus, reinstall OS and drivers
4.5.7. Check MAC address ( You could follow the commands: " Start"-" All Programs"-" Run", please input " cmd", after that you could input " ipconfig/all" to check MAC address)
4.5.8. If possible, use another computer in the same network environment to check if it can access internet
a. If the network connection is OK in another system, please contact reseller (service center) for tests
b. If the network is not connected to internet, please connect ISP and network peripheral reseller or change network cable
Mar 03, 2014 | ASUS SABERTOOTH Z77 LGA1155/ IntelZ77/...
Internet won't connect
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima
Apr 19, 2013 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Marvell yukon ethernet shows with yellow exclamation mark and will not allow me to connect to internet
The driver should be on the motherboard disc or the one supplied by your ISP internet service supplier
make very sure all leads are plugged into their specific connection plugs you might have to connect the usb lead to your modem to get a connection then
click start control panel,administrive tools,computer management,device manager scroll to network adapters could see a yellow question mark? right click install drivers
hope this helps if you cant find the driver hopefully one of these will help you
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
Feb 08, 2012 | Marvell Yukon 88E8001/8003/8010 PCI...
Laptop Toshiba L501 win vista home premium got problem RAS error code 608 when use with vodafone internet model K3765. This internet key work with other laptop run xp or vista... Could anyone please tell...
Error #608
Error Message: The device does not exist.
Solution:
1. Check that the right modem is set in the dialer
2. Ensure that you are using the right modem drivers by checking the modem diagnostics. If it’s not the case, set up the correct drivers.
3. Remove and install the dialer again
4. Your modem might not be working properly; try to install it again.
5. You should then consult your computer manufacturer if the problem persists.
Apr 12, 2010 | Computers & Internet
I need ethernet controller driver, PCI bus for Presario 6010US
Have you tried to download THIS ? The other drivers for XP is HERE if you need.
Apr 10, 2010 | Dell Latitude D410 Notebook
Cant play sound it keeps asking for multimedia audio controller when i install audio driver it states RPC Server not found
It sounds like you have the wrong driver installed or there are more drivers that you need to install and update.
One way to ensure that you install the correct drivers is to go through the Device Manager and update your driver.
This is for a Windows XP system
To Update your drivers through Device Manager, pls do the following:
1. Attach your computer to the internet, make sure you can get on the internet by launching your browser, ie. Internet Explorer, Firefox, Safari
2. Navigate to Start/Control Panel, System
3. Choose the Hardware Tab and click Device Manager
4. See if there are yellow exclamation marks or question marks listed
5. Select them and right click on each one (you have to do this one by one until you see no more yellow exclamation marks or question marks)
6. Choose Update Driver
7. Follow the prompts to complete (usually by clicking ok to all the prompts)
This is for a Windows Vista or Windows 7 system
1. Connect your computer to the internet and ensure that you have internet connection by launching your browser and surfing to your favorite website.
2. Navigate Start/Control Panel/System
3. On the top left hand corner, click Device Manager
4. Do the same from 5-7 under the Windows XP directions up above.
Again, remember that sometimes drivers are related to something else on the system. Therefore you may need to update one or more drivers. This is the only way to ensure that you get everything.
Let me know how it works out and please don't forget to rate me.
Mar 19, 2010 | Compaq Evo D500 PC Desktop
PCI Slot 1 (PCI bus 1, device 10, function 0)
Hi there,looks like your devices need updates to function correctly,
from devices manager,
select the device with the yellow question,
right click and click on update
even if you have no disk or internet
let the wizard find the drivers automatically
should be preinstalled with your OS XP
go thru your list and update any other question marks in yellow.
Should be able to update the network device on this system and then connect to the internet to finish anything else
heres the link for the Chaintech motherboards
http://www.download-device-drivers.com/Chaintech.php
Hope this helps,Cheers Misterdj
Jun 19, 2009 | Chaintech 9LIF7 i845G Motherboard
Error while attempting to install ScanSnap Manager on Win XP Pro
Bypass installation wizard and just run the setup.exe file for ScanSnap Manager. Installation wizard is bugged.
Jan 09, 2009 | Fujitsu ScanSnap Manager
No Internet
You may try checking the network driver of your computer.
1. click start --- right click "My computer / Computer".
2. click Manager then look for device manager.
3. under device manager on the left column. Look for your network adapter if it has a yellow question mark or a red x mark.
Red X - disabled.(right click then select enable)
yellow mark - driver is not installed/corrutped (you need to install the driver online or from the cd that came with the computer)
4. Restart
Now, if the issue still the same. Try a different computer and check if you can connect to the internet. If the issue still the same. Call you Internet service provider to check on the connection.
Keep me posted.
Thanks.
Oct 26, 2008 | Dell Inspiron 1000 Notebook
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
