The power cord works. Removed hard drive, RAM, and battery. Press power button and held for a minute. No fan start or screen display.
SOURCE: hp dv2000 won't turn on...
dude, I almost gave up.. try this link. Apparently lots of people experienced this problem so HP gave an extended warranty for models like these.
Here, more info: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
SOURCE: nx6310 wont stay on
HP is notorious for this problem. The problem is that the power jack that is connected to the motherboard has come loose. This is an easy fix is you are comfortable taking apart your notebook and are able to solder the jack back to the motherboard. I have 2 HPs and my friend has 2 and we have done this with ours as well as others. This is the link to the HP website that has your manual for disassembly .http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1839143 When you get to the page, download the Maintenance and Service Guide. (It is all the way at the bottom!) You will need Adobe Acroabt to read it. PRINT the instructions. They will do you no good if they are on the laptop that you are trying to disassemble!
While it may seem daunting, it is really not hard to do. Just be careful to follow all of the disassembly and reassembly instructions and you will have no problems. I promise!
Please remember to rate my solution! Thanks
SOURCE: dv2120us keyboard buttons light but screen black, won't boot
Hello Atty
I understand that your Notebook is not powering on. Your Notebooks , that is dv2120us is having a manufacturing defect. So HP accepted that the Notebook will be serviced under the plan "One Time Service Enhancement" . Even if the Notebook is out of warranty your Notebook may be serviced. For more information log on to the chat support .
.http://welcome.hp.com/country/us/en/contact/chat_1.html
They will assist you with the details and the procedure, how to send your Notebook to HP for service.
SOURCE: HP Pavillion Entertainment PC screen blank, power lights on
try this put off the laptop and remove the battery and the power cable and then hold the power button from 30-60 seconds then put back the power cable(without battery) and switch it on it should work then shutdown and put battery pack in
SOURCE: My compaq laptop doesn't turn on
At the bottom of the laptop, find and open the placing of RAM. Unplug each RAM from its bank, clean each RAM and also its bank, Plug them again in different bank. Lock your placing, now check.
Just remember to take your time and don't get nervous working on the computer. Please report back to the thread the results of your work.
Regards;
Hassan
