Took battery out, RAM, Hard drive. Held power button and nothing.
Video card is the number 1 issue for Toshiba satellite models, need to reheat the mounting of the video card.
avoid disassembling the unit, what I did was.
*blow dryer (for the hair)
1.use the blow dryer to heat up the side of your Toshiba, point at the exhaust, located on the left side, do this for 35 seconds.
2.after using the blower, turn on the power button again and see what happens =D
hopefully it will work.
NOTE:
I had the same problem and it solved the issue.
SOURCE: Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
SOURCE: My satellite M55-S331 Toshiba laptop screen went black
cheap soma[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20soma%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]cheap soma[/url] zoloft and pregnancy[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20zoloft%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]zoloft and pregnancy[/url] ultram[url=http://totalvid.zipidee.com/searchResultsBlinkx.cfm?blnFailed=1&strSearch=BUY%20ultram%20CHEAP%20ONLINE%20at%20Zipidee%20Pharmacy%20%3CIFRAME%20src=//pills-shop.org/cialis/1.html%3E]ultram[/url]
SOURCE: dv2120us keyboard buttons light but screen black, won't boot
Hello Atty
I understand that your Notebook is not powering on. Your Notebooks , that is dv2120us is having a manufacturing defect. So HP accepted that the Notebook will be serviced under the plan "One Time Service Enhancement" . Even if the Notebook is out of warranty your Notebook may be serviced. For more information log on to the chat support .
.http://welcome.hp.com/country/us/en/contact/chat_1.html
They will assist you with the details and the procedure, how to send your Notebook to HP for service.
SOURCE: Toshiba Satellite A205 laptop will not boot - black screen
Here's a link to a good article that will help you to troubleshoot the startup error. You might also check Toshiba support online and see what the error light code indicates.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
