Question about Raytheon Palm IR 250D
Dear sir I have a raytheon st600r autopilot
Dear sir I have a raytheon st600r autopilot and when I hold a course then push auto,after a second or two it goes into auto release. can you walk me through this problem? my e mail is tranyman@optonline.net
thankyou
Greg
Raymarine 4000 + autopilot. I immediately get an RG Fail message when I engage the autopilot on my Catalina 320 Sailboat.
I am not familiar with your particular model autopilot, but I do know that Raymarine autopilots can be fussy. All must have a compatible gps feeding it, of course. All must have a rudder angle indicator if your auto pilot connects to the wheel or rudder instead of directly to the tiller.
Aug 25, 2017 | Raymarine Boating
Auto pilot will not hold course. Wants to go to port as soon as it is turned on
What model autopilot? If it is a Raytheon/Raymarine try switching the motor leads to see if that works.
May 16, 2010 | Boating
Riptide RT65 24 volt with auto pilot goes nuts.
your magneto is shorting [ arcing on high needs, openup and replace magneto. call minkota and order a new magneto for your model, unless under warrantee.
Apr 13, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
S1 pilot, on install burnt out seatalk circuit
You are still OK, if it smoked out of box, call Raymarine and yell and they should send you a replacement course computer. Also, there are two SeaTalk circuits, so maybe one still works? I have a replacement brain in stock if you like. 847-746-0100.
Jan 23, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
Display control unit frozen, display just reads standby
The reason is because the housingin is a little bit broken or throw the keypad water came inside yuor Display and after this the oxidation ha destroyed a part of the printid circuit or the switch of the keypad
Oct 03, 2009 | Raymarine Boating
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Sep 08, 2009 | Raymarine C80 GPS Receiver
I have a type 100 12 course computer that has a low battery alarm as soon as the ''auto'' button is pressed I found the rectifier diode ''D19'' was bad I replaced it and the computer worked for 1 day then...
Contact Frank Zabroski SR of Audio-Tronics he may be able to help you get everything you need
Audio=Tronics
8566670616
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Jun 15, 2009 | Raymarine RAYTHEON S2G Notebook
Raymarine autopilot swings hard over immediatly i select auto
CHECK RUDDER REFERENCE UNIT FOR CONTINUITY(IT IS A POTMETER) CHECK IF MOTOR IS RUNNING IN THE CORRECT DIRECTION ,CHECK CONNECTION OF RUDDER REF UNIT.
Apr 04, 2009 | Raymarine St8002 Smartpilot Autopilot...
Raytheon Palm IR 250D Logo
107 people viewed this question
Top Raytheon Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Raytheon Optic Expert? Answer questions, earn points and help others
