A/C FAN MOTOR SHUT OFF, BUT CONDENSER KEEP ON RUNNING
I have a TempStar10 A/C unit for about six years now which had been working fine however, my problem is that the fan motor shuts off after a few mins, but the condenser keep on running, can someone help me out.
    Sergeant:
    Champion:
  • 235 Answers
The condenser fan might be going out. It'll start when cool but shuts off as soon as it starts to warm up.
Posted on Jun 28, 2009
  • 575 Answers
When you say 'condensor', do you mean compressor? A condensor is a coil, it does not run. The only thing that runs is a compressor, fans and blowers.
Posted on Aug 08, 2012
My refrigerator is not cooling properly. How can I find the source of this problem?
The controls on a unit like that cannot be set to extremes on one side. If you set the freezer to the wrong setting or the refrigerator to high then the balance is bad. The other thing is that the coils inside the unit might have ice on them and the ice is not defrosting. That means that no air is flowing through them.
Oct 15, 2014 | Refrigerators
Sub zero 736 condenser fan not running
You will need to remove the cover around the condenser fan motor then remove the screws holding it down to the base. Remove the wiring from the junction box and away you go. Do not run the unit without a working condenser fan motor, you run the chance of causing yourself many other problems. With a new fan motor the unit should run fine unless there is waxing in the cap tube from overheating. Good luck
Sep 08, 2012 | Sub-Zero Refrigerators
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
The capacitor was bad and was replaced. now the system will work fine for about 30 min then the fan the outside unit will stop working. it sounds like the compressor is still on and cold air is will...
Yes, if you changed the three post capacitor that runs the fan and compressor, and the fan is still getting hot and shutting down until it cools off, you may have bushings out of the motor or an internal short. Sounds like you have a job ahead of you of changing your condenser motor. If you do this yourself just contact me I will step you through it . Mark
Jul 10, 2011 | Goodman CLJ36AR42 Air Conditioner
It is a Bryant Legacy AC unit. Model #123RNA060-B. It has been running fine, now it has suddenly shut down. The interior fan is working, but the fan at the compressor shuts down. It will work fine for...
I had a unit do the same thing to me, everytime I would leave, it would stop working again. I had a bad fan motor that would spin fine and work for a little while, but would shut down. It was the motor windings that would overheat and shut off, as soon as they cooled, it would start back up. One way to check is to feel the top of the unit where the base of the fan mounts and see how hot it is, best to check while it's not working how it should, but try not to run it very long or you could damage the compressor. Hope this helps!
Jun 27, 2011 | Bryant Heating & Cooling
GE AEH10AMG1 was working fine a week ago. Plugged it into the same socket yesterday, and the breaker in the plug popped, and it keeps popping when we try to plug in the unit.
You have a direct short in the A/C unit probably at the compressor or your condenser fan motor. You can disconnect one component at a time to identify where it is shorting. turn power off unwire condenser fan motor secure wires so they dont touch anything plug unit in if it still pops breaker your compressor is probably bad.
May 19, 2011 | GE Heating & Cooling
AC Condenser motor will stop at 1pm but inside unit is still running but no AC. If I turn the AC unit breaker unit off and then an hour later turn it back on. The unit runs fine all day until 1pm. Had a...
Hi, the tech should have been able to figure the stat out with out a manual to see why the condenser is shutting off at 1:00 P.M. This is unusual for this to happen, unless it was winter and this is a heat-pump going into defrost, but just the fan would shut down. Does this unit have a box on it that was installed by your electric company that shuts the unit off during high peak conditions in the summer? This would cause it to shut down at the same time everyday. If not, it would have to be something in the thermostat that is set for it to shut off at that time. It still does not make since, as it would shut both the indoor and outdoor unit off, not just the condenser. Are you saying that just the condenser fan motor is shutting off, but the compressor continues to run until it shuts off on high head pressure when the fan stops, or does the complete outdoor unit shut down fan, compressor and all at that time??. It sounds to me like this outdoor unit has a time delay relay that has a fault in it may be shutting it off at this time daily? Please let me know if its just the condenser fan motor that shuts off, or if the complete unit is shutting off all together, this will help .
Sincerely,
Shastalaker7
A/C, Heating,
Sep 08, 2010 | Carrier 38CKC060 Air Conditioner
I have sheared one of four stud bolts that hold the motor fan on my York air condition unit. This is the outside compressor unit- central air. I bought a length of threaded rod to repair this bolt....
Hi, To give you an answer, no it doesn't take anything special to repair the condenser fan motor. This key stock you bought will work just fine as long as you can use it ok. Those outside studs tend to rust as they are in the weather year around, so I would cover it unless it is a heat-pump which runs year around. If not, you can cover it to keep the leaves and debris out of it. Just about any grade of threaded rod will be fine.
Sincerely,
Shastalaker7
Jan 01, 2010 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Control board reset?
Amana version of adaptive defrost : Press refrigerator light switch five times in six seconds to initiate defrost cycle. Pressing five more times within six seconds will cancel defrost and go straight into the run mode. Similar operation on both bottom mount and SxS refrigerators. After the defrost terminator/thermostat opens, six minutes of dwell time occurs before the compressor and condenser fan motor will operate. After defrost terminator/thermostat open, 10 minutes of dwell time occurs before the evaporator fan motor will operate.
May 04, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Heating & Cooling Logo
485 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
