Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
My insignia bluetooth headset will not turn off
The blue power on light is staying on constantly and not flashing every few seconds like it is supposed to, and when I try to pair it with any device the device does not see it, so ultimately I want it to work again.
Plug the power adapter into the headset. Then press the Volume up and down buttons (+ and -) on the headset simultaneously. This will reset the device.
Posted on Jul 22, 2009
  • ayana8294 Mar 19, 2011
    This response was awesome! My husband's bluetooth light was on for hours. I tried this suggestion and it worked immediately. Thank you!
    Problem Solver:
  • 5 Answers
Let the battery drain
Posted on Jul 15, 2009
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Tip
How to connect a (Motorola) Blue Tooth headset to a mobile phone!
The following procedure is dependent to the phone in use! However it is mainly for Motorola brand but it works with many others too!
1. Turn on your mobile phones bluetooth function and go to search for new devices menu.
2. On the headset, From turned off state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on (or in other brands flashining very fast) which means the headset is in receiving/searching state!
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone (the light flashes slowly) and will be ready to receive calls!
Best wishes
Bruce
on Jan 27, 2010 | Cell Phones
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Insignia Bluetooh Headphone won't turn on. but can charge
put the charger in your headphones and hold both volume buttons
you should see a slight flash of blue light then press the multifunction to turn it on
Jun 19, 2009 | Insignia Bluetooth Wireless Headphones...
Where?
power button is the little nipple between the phone and play/pause pictures on right side. You hold down for 2 seconds until blue light comes on to turn on.
Too shut off hold down button 4 until red light comes on.
if want too pair with device hold button down 6 seconds until light blinks blue red
pass code is 0000
May 15, 2009 | Insignia Bluetooth Wireless Headphones...
Light stays on when i turn it on, cannot connect
For this headset, the Blue light should blink before you can connect it via Bluetooth.
Have you tried holding down the multi-function button of it for 7 seconds and then release it? If not, try that until the Blue light flashes. If it will not work, refer to the user manual of the headset or this could be a defective one.
Apr 14, 2009 | Jabra Bluetooth Headset with Adjustable...
How do you pair your Insignia Headphones/ Headset with a PS3? It is called an insignia NS-BTHDP/NS-BTHDST. In the instructions it only talks about pairing it with a computer. Can someone help me?
Go to Accessory Settings on your PS3.Then go to mange bluetooth devices and hit register new device. while doing this take your headset and put it in discovery mode. You do this by holding the power button and the it alternates between blue and red lights.It should work after that.
To test it go to audio device settings and see if it shows up.
Mar 26, 2009 | Insignia Bluetooth Wireless Headphones...
Bluetooth pairing
Try the following:
a) Options->Bluetooth->Enable Bluetooth
b) switched on the Moto headset (blue light blinking)
c) options->bluetooth->add device
d) searching for devices....---> here it should find the headset and pair....
If it does not work do the following
After doing the above, do the following:
e). Start the headset. Start with the headset powered off, and hold the Call button for 10 seconds or so, until the light stays on. (Initially, the light will flash a few times before getting steady.) If the light is flashing, or if the light starts flashing anytime during steps f) through g), the headset is not in pairing mode, and this step (step e) must be repeated, again starting with headset powered off.
Select the Headset:
f.) Go back to phone, and select "[Look for Devices]." The phone starts searching for Bluetooth devices.
g). Once phone is finished searching, you get a list of one or more devices under the heading "Scan Results." Select the headset.
h). The next screen will read "Bond With ..headset." Select "Yes."
i). The next screen will be "Enter Bluetooth Passkey." Enter 0000 and select "OK." A screen will confirm pairing and connection. When the pairing is complete, the light on the headset will flash.
Sep 13, 2008 | Cell Phones
HBM 750 BLUE LIGHT STAY ON
I have the same model, and if you turn it on and the light stays on, usually after a flash and about 10 seconds, your headset isn't paired with your phone. You need to re-pair it with your cell phone, the code is 0000. That should work.
Jun 29, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
884 people viewed this question
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
