Question about Bugaboo Cameleon Stroller
When the frame is fastened to the chassis the 2 round white buttons will not lock into place and so the frame will also not lock into place
  • 29 Answers
You can get that fixed by us www.buggypitstop.co.uk visit our site and email us if you need more assistance
Posted on Dec 08, 2009
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
Apr 10, 2016 | Buick Cars & Trucks
When the baby is in the stroller, the stroller unsnaps and begins to fold. What is going on?
I think your problem is that the chassis does not lock into place (if this is a quinny stroller we had a similar problem a few times). Just open up the chassis, let it go all the way up, and then firmly lift the handle holding the frame down, until you hear the frame click -- that means it is locked into place. Then you can insert the seat in place and it should not fold down on you. Put some pressure on the seat and if it still folds down, then the locking mechanism is bust and you can take it to the dealer to have it checked. Good luck!
Feb 01, 2012 | Quinny Buzz 3 Stroller
My bugaboo cameleon frame wont click on the chassis
The chassis must be fully opened out and the handle locked in position before the seat / bassinet frame can lock down on to it. The seat / bassinet frame is the safety lock keeping the frame ridged. You should see a square hole (made by two half squares from adjoining hub disks) at the top of the chassis hub assembly when fully open. A square pin under the seat frame must engage into it and the white release button must click. Your Bugaboo will not br safe unless this happens and you should contact the seller to help.macnutz_36.jpgmacnutz_35.jpg
Jul 10, 2011 | Bugaboo Cameleon - Tailored Fabric...
How do i put the chassis up and down
Push in the little white button on the frame handle and pull the 2 buttons on either side of the handle - if the frame doesnt fold doew gently move the handle a bit untul you hear a click then should fold
Jun 18, 2010 | Bugaboo Frog - Black Stroller
My bugaboo cameleon chassis 2007 model won't open,
Go to www.buggypitstop.co.uk they are the only company that repairs bugaboo chassis
May 19, 2010 | Bugaboo Cameleon Jogger
Our round white buttons on our bugaboo are stuck and won't lock
we had the same problem. spoke to bugaboo and they sent a new bit. think the spring goes inside. easily fixed with the new bit.
Nov 15, 2009 | Bugaboo Cameleon Stroller
How to install a rear window regulator on a 2000 Oldsmobile Intrigue
How do you remove door panels and replace window regulator on an Intrigue? Answer : For a 2002 Intrigue – Front Passenger I didn’t disconnect battery. You use window switch later to align window tabs to regulator frame – with ignition off power locks work, nothing is exposed.
1. Remove visible screw under armrest, pop out finger inset oval panel, remove exposed 2nd screw. 2. Pop off door handle trim – lock button assembly slide thru its hole in door panel. 3. Pop off window switch trim/holder – slide thru its hole in door panel. 4. Remove 2 slot screws under bottom of door.
5. I used a smooth metal letter opener (or old fork) to pry panel from door at each point plastic fasteners insert into metal. Start prying a little, see three on bottom perimeter two inches from edge. Three on door open edge and three on door hinge edge. Slow and easy = whole panel will pop off. A metal compression spring fastener connects at top door hinge edge trim – pry out. Be sure door lock and window switch remain inside. Clean all surfaces of door panel and lay on back seat.
6. With panel off you see clear plastic moisture sheet stuck to door with black rubbery paste - peel it from door for reattachment. You now see mechanism and fastener points. Lay out replacement window regulator and motor on mat by door to help you recognize fastening points, etc.
7. Carefully pull glass all way up and hold in place with two pieces duck tape two feet long with ¼# removal tabovers. Put a foot on outside glass and loop over door frame a foot to inside glass – with room to later redo when you twice lower and raise a foot to access bolts removing/attaching it to regulator bar.
8. Remove 3 bolts holding motor to door. 9. Remove upper 2 bolts and lower 2 bolts holding regulator frame to door.
10. Lower window to expose thru panel cutout area two bolts holding glass tabs to regulator, retape securely. Remove bolts, raise window, retape securely by looping over door frame.
11. Window regulator and motor assembly comes out as unit. Unplug window switch tab to release from motor. BEFORE reassembly clean the inside of the door, put in a little Borax for bugs, etc.
12. Reassemble by starting three motor bolts, fitting regulator assembly in door cavity. Replug window switch, motor can be placed in thru oval slots, leave all bolts loose. Replace two upper and two lower regulator bracket bolts, leave loose.
13. Turn on ignition, use window switch to lower window glass regulator tab bracket until accessible thru panel cutout. Turn off ignition, manually lower glass until tabs align with regulator bracket bolt holes and tighten these bolts. Take tape off, turn on ignition, raise window to top.
14. Tighten three motor bolts and four regulator bracket bolts, make sure alignment is OK. Remove your tape residue - clean goo from both glass sides with Goof Off. THEN raise and lower several times to assure all fits and works like new.
15. Reinstall clear plastic sheet, aligning any fastener holes and rubbing down perimeter with a cloth .
16. Align door panel, assure door lock and window switch are pulled thru. Visually align each tab on door opening side and pop them in one at a time. Continue on bottom – make sure you see them align or they will break. Finish on door hinge side and with metal fastener at top. IF you break a fastener, take one from small bag you bought from Pep boys - otherwise take bag back for refund…
17. Reinstall 2 armrest screws and 2 bottom panel screws, then pop in door lock, trim piece and window switch.
Clean the window inside and out with glass cleaner/polish/raineze so it will slide easily and your done. You can’t do anything about the motors going out. You can avoid regulator tab breaks by making sure the window is raised BEFORE closing those big doors – down is the weak moment!! I work slow and clean as I go, the job took two hours. I highly recommend partsgeek.com – saved a bundle over dealer and they shipped everything in several days – as ordered!
Jul 27, 2009 | 2000 Oldsmobile Intrigue
Need info on how to remove driver side door panel. I'm trying to install a new electric window assembly on a 02 Dodge Caravan Thank You Dave
I can give you generic info on how door panels are fastened and removed. I hope this helps. The outer perimeter of the panel is held in place on the sides and bottom by push-in fasteners that match holes in the door frame. These fasteners have button heads that attach to the back side of the panel, and the have ribbed shafts which are pushed in to the door frame holes. There are screws and/or bolts that secure the door arm rest and door handle molding to the frame. In some designs the screw head are concealed by small buttons, or by a piece of molding plate that pops out.
First step is to locate and remove all these screws. Next step is to place a screw driver at the edge of the door panel, between the panel and door frame and pry the panel away from the frame. There is a trim tool that is made for this task (relatively inexpensive) that you can purchase at the local auto parts store. The sides and bottom of the panel are popped away from the frame. After sides and bottom are loose, the top is released by pushing up to release the upper window molding from the frame. Be careful of wiring on the back side of the panel (electric windows, locks, etc.) Unplug all electric before you remove the panel totally.
Those nylon fasteners tend to break when the panel is removed, but they are replaceable (again, at your auto store). Just take one with you to match it up.
I hope this helps you!
Jul 25, 2009 | Dodge Caravan Cars & Trucks
The frame wont click into place
My daughter has just brought me a Bugaboo which is 25 months old (one month out of warranty) and after several hours work I have figured out the problem.
The reason that this seems to occur after a year or so is, I believe, related to the fact that the housing in which the white button sits is made of thermoplastic and is not dimensionally stable. For the button to work properly both the circular hole in which the button sits and the button itself must be circular and the button must be very slightly smaller in diameter than the housing. If either of these are slightly distorted the button will stick.
The other thing to know is that when the cradle is off the chassis the button will always be in the 'in' position. What pushes it out is the pressure of the part of the chassis on which the cradle sits when you push the cradle onto the frame (you can demonstrate this by getting a screwdriver or thin dowel) and pusing down on the plate within the socket on the cradle that sits on the chassis - when you do this the button will pop out and when you take the pressure off it will pop in again).
If when the cradle is attached to the chassis the button is not out, give it a few quick sharp presses on one side to make sure it isn't binding on the plastic within it sits.
This should releases it.
The cure? You need to dissamble the button assembly and spray some silicone lubrication or similar and make sure the various parts are working smoothly. Also you need to check to see if the white button is binding on its black housing. If it is, then carefully use some wet and dry paper or similar abrasive on the circumference of the button until it stops binding
Having figured out how this works I have to say that I consider the mechanism to be a very poor one considering the price that is charged for Bugaboos. If they took a little more care and made sure the button and housing wouldn't distort with age and bind, the problem wouldn't exist.
Hope this helps.
Nov 14, 2008 | Bugaboo Cameleon - Tailored Fabric...
Hi, my bugaboo is now 16 months old and recently the round white buttons on the side that lock the seat into three different positions got stuck instide, so the seat is not locked in any position, which...
Hope this helps. .
Aug 11, 2008 | Bugaboo Cameleon Jogger
Bugaboo Cameleon Stroller Logo
143 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
